Cylinder miss....no spark....please help!!
MY car (82sc) was only running on 5 cylinders when I started it up to run some errands Saturday. I determined that it was the #2 cyl. (driver's side, middle). I changed the spark plug, to no avail. Then I put in another new plug....no difference. Since then, here's what I've done:
* put a brand new wire on, thinking it was a connector
* changed #2 & #3 cylinder wires and their corresponding
positions at the distributor...miss still occurs on #2.
* cleaned contact points in the distributor and on the rotor
If I pull a running cylinder off of the distributor, I'll see it arc, but no such thing with #2 cylinder wire if I disconnect it from the distributor.
All components are only about a year old and the car is always kept in a good state of tune.
Any ideas?
'82 911 SC
Old 10-03-2004, 01:05 PM
Sounds like something is up with your distributor cap based on the no-arcing description. Do you still have the old one to test with?
Ken
1986 930 2016 R1200RS
Old 10-03-2004, 01:17 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Steve...I'm having the same exact problem. Did you fix this?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-19-2013, 09:37 PM
T77911S's Avatar
peolpe always complain when someone does not do a search. you certainly cant be called out on that one. nice that there is no follow up.
that post is nearly 10 years old.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-20-2013, 03:04 AM
