craigster59's Avatar
83 911SC CIS computer
Does anyone know of a source for an OEM or remanufactured CIS computer for my 83 SC? I'm having a hell of a time getting my car smogged here in Calif. Thanks, Craig
Old 10-06-2004, 08:54 AM
Loren does them I think if you search you'll find the link
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-06-2004, 09:03 AM
Hilbilly Deluxe
emcon5's Avatar
Just curious, what makes you think you have a bad "brain"?
Tom
82 911SC Coupe
GTI Cup #43
Old 10-06-2004, 09:39 AM
yeah, the relay, or no power to the relay is the most common problem. computers don't fail much.
206 637 4071
Old 10-06-2004, 09:43 AM
Lorenfb's Avatar
John is correct. The failure rate is very low.
Check the following:
1. +12 volts on pin 8
2. +12 volts on pin 15 (return connection from freq valve)
Checks that freq valve gets power from the relay next to the Lambda unit
3. grd on pins 5 & 16
4. O2 sensor on pin 2
5. Cold running enrichment on pin 7
6. Make sure the relay (next to unit) is the correct one.
If the Lambda unit is removed while warm and running, the idle will drop.
Grounding the O2 sensor causes the engine to run rich.
Note: If the Lambda unit is bad, check with Tom Gould at Pelican for a
rebuilt unit. Remember, Pelican has many sources for many parts not
shown on the Pelican web site. Just ask!
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-06-2004, 10:37 AM
Hilbilly Deluxe
emcon5's Avatar
Loren, if the Frequency Valve is working at all, wouldn't it be an indication that the "brain" is OK? By working at all, I mean vibrating, with a measurable duty cycle at the test connector near the fuse block?
Thanks,
Tom
82 911SC Coupe
GTI Cup #43
Old 10-06-2004, 11:00 AM
Lorenfb's Avatar
Yes, Tom you're correct. Although, the valve may be plugged. Next test is to ground
the O2 input to check full functioning. The idle will drop and the engine will run rich.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-06-2004, 11:09 AM
