dweymer's Avatar
part help---
I need studs for the two holes in blue, any ideas on what they should be?
Donnie
Currently Porsche-less.....
Old 08-11-2006, 12:10 PM
911quest's Avatar
They are 8 by 1.25 studs
Tony Proasi
1969S
1957 VW Pickup
Old 08-11-2006, 12:29 PM
The length of the studs will vary depending on whether you have any accessories attached at that point (e.g., smog pump). I have two of the longer ones (w/ smog pump) if you'll pay for shipping. They are too long, however, and will not work without the smog pump bracket. Send me a PM if the studs will work for you.
Rich Kessel
79 R.o.W. 911 SC
Old 08-11-2006, 12:45 PM
The correct studs (if you are not putting back on the smog pump bracket) are BM6x42 (6mm x 42 mm long); Porsche Part no.: 900.061.092.02. The 1.25" length listed above is too short for the extended bosses on the version of the chain cover shown in your posted image, the 42 mm or about 1.65" length is required.
Old 08-11-2006, 12:57 PM
911quest's Avatar
I was talking about the thread pictch
Tony Proasi
1969S
1957 VW Pickup
Old 08-11-2006, 01:26 PM
"I was talking about the thread pitch."
I stand corrected. You're right about the stud size (and pitch) for the smog pump mount style cover plate. It appears one needs about a 50mm long M8 x 1.25 stud for the smog pumpcover plate. The 6mm (x1mm pitch) x 42 mm stud I listed is used for the early cars when they receive the new left side chain case cover for updating to Carrera pressure fed tensioners.
Old 08-11-2006, 02:18 PM
