bent aluminum cross member - can it be fixed?
I have a spare aluminum crossmember that is a bit bent - Is it possible to straighten this piece or is it destined for the junk pile in the corner?
Thanks, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Andrew,
That is a cast part. If you attempt to straighten it there probably be a weak spot subject to failure or corrosion. Polish it, relegate that to a wall trophy, and fine a straight one. Is anything else damaged? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Make Bruins Great Again
I agree with Grady. Bent parts will have less strenght and be a failure waiting to happen. The only thing I could think of to save replacing it would be to somehow brace the bent area (weld or bolt on). Grady?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Thanks Guys - thats kind of what I thought. I've already put a straight / undamaged one on the car, so I was thinking of keeping this as a spare. Looks like it will be tossed out so it doesn't get on a car again and potentially cause problems..
AM
Mine has a slight bend but is still working fine, I do keep an eye on it though
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
aluminum does not like to be bent
