header oil line
I just discovered some hack job the prior owner did yay, the prior owner hammered the header to make a very slight clearance for the oil line... how risky is this situation? What is the correct oil line for this application? Am I correct this needs to be addressed immediately
Old 07-13-2015, 06:51 PM
porschetub's Avatar
OMG,thats not too flash,you can see how hot the return pipe has been getting close to the exhaust,best solution is to get the bend shortened away from the header pipe,any good welder with a tig could do it but make sure you clean the pipe internally after welding.
You may need to reshape the pipe to get you back to your mounting support clamp,not really a hassle as the pipe is soft anyway.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-13-2015, 08:11 PM
Elombard's Avatar
you need the return line from an early car or elephant racing makes another solution that our host sells.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-14-2015, 03:31 AM
wayner's Avatar
Note the lack of underslung oil line
Used this instead: Elephant Racing 1B - Universal Crossover Pipe - Specialty Type - 0180000
SOLD - 914 wide body hot rod
Old 07-14-2015, 04:10 AM
BoxsterGT's Avatar
Porsche Crest
If you want to keep this header for performance reasons, you need the early cross-under pipe as described above. It is PN 911.107.739.10 and available from our host.
Of course, then you need the connecting hose to the thermostat or tank. If you want used, they are readily available from many Pelicans including myself.
To save this expense I can modify your stock hardline to clear as I have done for others. I often make up custom fittings & lines such as these..........
for similar needs.
Len at Autosportengineering dot com
Old 07-16-2015, 08:20 AM
