Bob Prosser's Avatar
Question Someone plz check rear wiper wire color sequence?
Re '89 Carrera rear wiper.
Can someone help me out, please. I need to verify the color sequence of wires that plug into the rear wiper motor. See, I had my whale tail repainted recently. The shop seems to have messed things up while reinstalling the engine lid because now the wiper does not return to its upright position. It just stops wherever I turn it off.
I have looked everything over closely. The reset mechanism -- the points that open and close -- look to be operating as they should, at least physically.
Thought I'd check the wiring. Presently, I have this sequence, going from the front to the back (in line with the car's direction of motion):
1.) Connect 53 -- red w/black stripe
2.) Connect 31b -- brown w/white stripe
3.) Connect 53a -- red wire
4.) Connect 31 -- brown wire
Any ideas? Thanks a million.
- Bob
Old 10-10-2004, 02:27 PM
Make Bruins Great Again
Por_sha911's Avatar
On the `87 as it was being removed:
Joe
Old 10-10-2004, 08:44 PM
Joe, thanks.
It's hard to tell for 100% sure, but it looks like that far left red wire has a black stripe ? If so, my wiring is correct.
4.) Connect 31 -- brown wire (ground)
Can anyone check their shop manual to see if those connects match up?
Also, there is a small wire inside the cover cap that connects to one side of the armature. It seems to be powered because if I pull it off, the motor will not run.
I guess I need to find a wiring shematic to check power to each wire.
- Bob
Old 10-11-2004, 09:18 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest rear wiper
Picture rear wiper motor 1985
Kees.
Old 10-11-2004, 09:56 AM
AH HA! From the diagram, I see there are TWO power inputs. I had checked the 25 amp fuse in the front, but did not think to check for another power circuit in the engine bay. DOH! I just did. Yup, it was blown. New fuse ... end of problem. Gentlemen, I owe you a beer. THANK YOU!
- Bob
Old 10-11-2004, 12:51 PM
galwaytt's Avatar
rear wiper motor.......more...
just a small bump on this, as you gents are likely to be familiar with the circuit - anyone else - please chip in!
The rear wiper hasn't worked on my car since I got it, 12mths ago. Pulling in to the car park at work on Friday, I notice in the rear view mirror, that the wiper is working !! One of the kids must have been at the switch. Anyhoo, park the car, but the motor hasn't twitched since.
I opened it up last night, and found one broken wire on the armature, but even patching that, it still wouldn't work. However, if I squeeze the contacts together, it runs !! See here
Question is, what is the normal situation for these contacts? Closed/Open, or what.....? Any info on re-furbing it would be appreciated.
John M
Co Galway, Ireland
'87 911 Carrera Sport......not any more....00 TT quattro...oops, gone too....'94 968...for now...
..no, add a '93 968 Tip to that. Hey, two cars are better than one, right ??
Old 02-21-2005, 05:00 AM
kees's Avatar
Porsche Crest rear wiper motor
Hi John,
Two pictures of my spare rear wiper motor.
When I'm back from work I can send you some pics with the rear wiper motor in the car.
Kees.
Old 02-21-2005, 05:52 AM
galwaytt's Avatar
dank je vel !! (I think I've got that right...........)
It looks like contacts 'normally' closed?
John M
Co Galway, Ireland
Old 02-21-2005, 05:59 AM
kees's Avatar
Hi John,
My pleasure. The contacts are 'normally'closed (wires are not attached).
The contacts in the car (wires attached) are also 'normally' closed (just checked it).
Kees.
BTW: You were almost right, it's "dank je wel".
Old 02-21-2005, 06:10 AM
Upier's Avatar
Bump
Old 07-16-2015, 07:29 AM
