Tony
Maxhouse97's Avatar
Turn signal assembly front bumper - how to reinsert?
Was trying to remove the bulb and these pieces came out. Can anyone tell me how to put the bulb back in? Does the hexagonal washer go in first and then the spring followed by the bulb? Or do they (spring and washer) go behind the contacts in the socket?
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 01-22-2015, 06:39 PM
I just rebuilt my signals, so I can answer.
First, to make it easier, unplug everything (make notes where each plug goes obviously). Should be a ground to the housing, 2 connections to the plate behind the bulb, and 2 connections to the BACK of the housing.
Then you can see clearer that the way it works is the brown electrical plate contacts the back of the bulb when it's inserted. The spring goes behind it in the open cylinder section, then the hex piece traps the spring in place. It gets bound by two small "teeth" on the ends of the cylinder section. You might have to get everything put together then use a drift or something to peen the "teeth" down a bit to really capture it.
The spring pushes the contacts against the bulb when you push it in and turn it.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 01-23-2015, 09:06 AM
Tony
Maxhouse97's Avatar
Awesome thanks! That makes sense.
Old 01-23-2015, 11:18 AM
