-   -   3.2 to 3.5 - Part II (http://forums.pelicanparts.com/porsche-911-technical-forum/186906-3-2-3-5-part-ii.html)
Carrera3.5L 10-12-2004 10:26 PM
Hi Guys,
Been a few weeks (see different thread for teardown info), but the 3.5 is finally getting screwed back together. Got the boattailed and shuffle pinned case back from Ollie's as well as the magnafluxed and micropolished crank. Rods were reconditioned and balanced as well and everything (and I mean EVERYTHING) has been thoroughly cleaned! Motor will be a black & silver combination thanks to powdercoating and fuel lines are now braided stainless hose rather than old, cracked rubber. Outer fastening hardware has all been cadmium plated as well.
No pics available yet, but here are a couple of shots of the 1 5/8" headers by George Narbel that I will be using in an attempt to get to 240 rwhp.
http://forums.pelicanparts.com/uploa...1097644201.jpg
http://forums.pelicanparts.com/uploa...1097644238.jpg
Once the motor has been broken in, will try and dyno the stock heat exchangers with Dansk pre-muffler and 1 in 2 out stainless muffler w/ 84mm tips and then swap over to the headers and Dansk 2 in 2 out stainless muffler also with 84mm tips for a comparison. Even though the results may be a bit off since the motor is a built 3.5 versus a relatively stock 3.2, it should give some sort of indication how restrictive the stock routed exhaust is versus headers.
One more teaser image:
http://forums.pelicanparts.com/uploa...1097644548.jpg
Twin-plug 3.2L head with "cleaned" up intake ports. New intake valves and all new guides.
Would like to post more, but am under a kind of "gag order" with European Car Magazine. Wrote and submitted part 1, hopefully the readership will like it. The non-Porsche reader is going to snicker about the dollars spent versus the gains realized though. $5,000 put into a VW 1.8T will easily get you to 300 bhp. Oh well.
Ralph
WydRyd 10-12-2004 10:35 PM
VERY NICE!!! Keep us posted on Dyno results :cool:
"$5,000 put into a VW 1.8T will easily get you to 300 bhp. Oh well."
$5000 put onto the stock 3.2 would have easily gotten you to 400bhp @ 0.7bar, but hey, not all of us are forced induction fans :)
Carrera3.5L 10-13-2004 07:59 AM
Merv, I just knew this was going to be your response about 5 minutes after posting.:)
With Mahle P's and C's and a bunch of machine work, the first $5,000 has long come and gone.:( In fact, $10,000 has also come and gone.:eek:
Thank god for free labor!
Ralph
911teo 10-13-2004 08:24 AM
I am looking into "upgrading" my stock 3.2L. I am willing to budget 20-23k. What is best route? Am I unrealistic if my target is 260 rwhp?
Is it easier to drop a Varioram in the car?
I will fully pay for labor....
CBRacerX 10-13-2004 08:29 AM
911Teo - You could have a very nice 993 engine installed for that budget (less actually).
Carrera3.5L 10-13-2004 09:34 AM
260 rwhp is very, very optimistic (re: not bloody likely) for a 3.4L or 3.5L twin-plug onversion still using the standard Motronic injection and cams running on pump gas. Changing to aftermarket engine management, further increasing the compression ratio and using suitable cams among other bits would get you there with little difficulty. 300+ rwhp is realistic for a fully race prepped 3.4L or 3.5L.
A slightly modified 993 Varioram motor that is perfectly suitable for street use should get you to 260 rwhp with no problem. If your 3.2L is in good shape, you can deduct some money off the sticker shock by selling the 3.2L motor.
In my case, I wanted a freshly rebuilt motor rather then rolling the dice on a transplant and finding out something was wrong internally. Since the guides on my 3.2L were worn, my motor would be worth much less on the open market and I don't have the conscience for selling it to somebody without telling them of the problem. Also wanted the originality of my engine case and other then the 993 distributor it will look much like the original 3.2L, just prettier! Will still pass CA emissions as well by removing the headers and reinserting the standard exhaust.
I estimate the motor I am building to be in the 15K range if labor is included, but bear in mind that you can still do this for cheaper then what mine is costing. The price quoted includes many ancillary pieces such as new head temp sensor, reference mark sensors, 02 sensor, motor mounts, fuel line replacements, muffler straps, starter ring gear, etc, etc that can be reused in many instances. This would knock down $1-$2K off my rebuild. Since everything is easily accessible with the motor out, I have caught the proverbial "for $100 more" syndrome.
It all depends on what your goals for the car are. If you have 20-23K to budget, I would look at a 3.6 Varioram as a serious option although Merv is going to try and convince you otherwise.:D
Ralph
911teo 10-13-2004 09:40 AM
I was thinking of 3.7, RSR cams, Pistons, titanium valves etc. I am an illiterate at this point but have just bought BA's and Wayne's books on the 911 engine....
I wanna keep it NA.... I know i could bolt a turbo on it and easily get 400hp...
My 3.2 has 125k on it... so not sure how much I could get for it...
tmsoko 10-13-2004 10:13 AM
What kind of money have you put into machine work on this engine. I have a 3.2L core engine and good 964 3.6L crank that I have been contemplating a 3.5L of my own. I would use JE pistons with my KS cylinders overbored and Pauter rods.
My end result would be different, as I am planning an Autorotor 1.5L supercharger with Ford EEC-V engine management (cheap parts and fully controllable with SCT Pro Racer engine software ($800).
My problem is understanding the true machine shop costs for block prep, head work, crank upgrades, etc..
Carrera3.5L 10-13-2004 10:40 AM
If you have a 3.6 crank already, you can make your 3.2L into a 3.6L just by using specially modified 100mm pistons with the stock 3.2L rods. Andial has the drawings to do the addl. piston machining.
Let's just say alot for machine work. Again, some of these mods can be bypassed if a strict budget must be adhered to.
$700 to:
disassemble heads
bead blast heads
polish intake ports
replace 12 guides
replace/regrind valves
grind valve seats
valve job
machine spring seats for AASCO springs
set valve spring height
reassemble heads
$290 to twin-plug heads and valve covers
$225 to surface and bevel heads for 100mm bore
$100 to hot tank case, r&r oil galleys and clean oil squirters
$40 to remove old head studs
$170 to machine engine case spigots for 100mm bore
$200 to boattail engine case
$295 to shuffle pin engine case
$215 to recondition rocker arms and polish shafts
$80 to moon cylinders
$60 to magnaflux and micropolish crank
$150 to recondition connecting rods
$150 to balance engine complete
$50 to surface 240mm G50 flywheel
It all adds up in a hurry, doesn't it?
Ralph
Carrera3.5L 10-13-2004 10:45 AM
Unless you change the injection, RSR cams and Motronic won't mix well. If you decide 3.7L you can use your stock 3.2L crank and just get the 102mm Mahle pistons & cylinders from Andial and upgraded rods from Carillo or Pauter.
Ti valves are expensive and overkill for street use. What would you be using the motor for? Street, race or some combination thereof?
Don't know the going price for used 3.2L's, but would guess it would fetch at least 5K if in good condition.
Ralph
tmsoko 10-13-2004 04:45 PM
Ralph [/B]
Yeah, you are not kidding! I was suprised by the cash into the heads I did not figure anywhere neat $1200! I was suprised the spigot bore at $170, I figured a bit more. Although, equally suprised with the $295 for shuffle pins - include an align bore/hone as well?
As for the pistons and rods, I will probably keep with the over bored 3.2L jugs and JE pistons, as I need custom low compression pistons anyhow and could avoid the spigot bore and associated issues. 2mm bore just isn't worth it when I plan to force feed the engine anyhow! Pauter rods will replace the stock rods for a more comfortable feeling when I step into it!
Thanks for the info it was great. Did you have everything done at Ollies?
WydRyd 10-13-2004 05:19 PM
Sorry Carrera3.5L, your engine is VERY sweet, I'm not denying that at all. I'm just a forced induction JUNKY, so don't mind my comments ;)
Having said that, 911teo, for much less than your budget, you can easily Twin Turbo that sucker for over 650+HP using 97mm, 98mm or 100mm P&C's and lag would hardly be noticable.
Just ask "Mike the mechanic". He's done such a conversion for significantly less that what your budgeting :cool:
Again, this is just the view from a boost Junky ;)
Walko 10-13-2004 05:28 PM
Ralph,
when you talk RWHP what factor are you allowing for drive train loss.
I had a 3.2 on MFI with RS cams that made 228RWHp and the motor wasn't twin plugged.
One of the guys I race with has a 3.5 on aftermarket injection with GE 100 cams his motor is supposed to be making 280RWHp
Michael
911 74 Modified
911 71 Stock
Carrera3.5L 10-13-2004 07:46 PM
Originally posted by Walko
Ralph,
Michael
911 74 Modified
911 71 Stock
I'm figuring 15% for driveline loss. Can't tell you if that is 100% accurate, but seems to be an acceptable figure with many.
If the percentage is correct, 280 rwhp would be about 330 crank horsepower, which is probably consistent with the mods you describe.
Ralph
Carrera3.5L 10-13-2004 07:55 PM
No offense taken at all. That's why I put a happy face! I've never been a turbo guy myself, but I realize the limitations of staying normally aspirated. I just want a strong and dependable street car that I can drive everyday and not have to cower when C5 Vettes or the STI/EVO 8 crowd comes calling. I'll have a little something for them I think.:D Gotta make sure she'll live on 91 octane and pass CA emissions though. Would be tough to do easily with an aftermarket turbo package unless I found a smog station on the take.
Yes, Ollie's did all of the machine work. What's the old saying, you have to pay if you want to play? I think the prices charged are reasonable, it just costs a boatload for everything. That's why I tried to spread everything out over the past 5 months, so it wouldn't hit me all at once.
Ralph
Carrera3.5L 10-13-2004 08:05 PM
The bottom end is together! 2 hours from start to finish tonight.
http://forums.pelicanparts.com/uploa...1097722660.jpg
http://forums.pelicanparts.com/uploa...1097722698.jpg
Sorry, can't show the internals going together because of the "gag order". Everything went together perfectly thus far, case is sealed and case through-bolts torqued to 30 ft/lbs.
Tomorrow night we'll install the ARP head studs, connecting rods with ARP bolts and maybe get to the 100mm piston and cylinders.
I know some of you are thinking why didn't the rods get installed before the case was sealed? Answer is personal preference. Installing the rods before the case is sealed is obviously easier because you have no problem with space but with the case sealed you have to do it through the cylinder bore in the case which leaves less room to play with. My buddy Steve (formerly of PMNA) prefers to do it this way but says it really doesn't matter.
Ralph
WydRyd 10-13-2004 08:52 PM
Nice, did you upgrade the piston squirters as well? A common upgrade for high compression (or high boost) applications is to install 964/993 piston squirters which keeps the pistons cooler under load :cool:
Carrera3.5L 10-13-2004 09:22 PM
Merv, thought about it and asked my buddy what he thought and he said I should be fine and figured here was an area where I could save a little bit of money by reusing what I have. They have been cleaned and should be good to go. Good advice to throw out there though. If only I had an unlimited budget and could get everything I really wanted...
Ralph
WydRyd 10-13-2004 09:26 PM
Ralph, if you had the case split already, it wouldn't have cost much more to upgrade the piston squirters as these are very cheap items.
Anyway, I think this upgrade is probably more suited to a big boost turbo application which results in a higher effective compression ratio under full boost, therefore higher piston temps.
I think in NA trim, you'll be OK :)
jpahemi 10-13-2004 11:20 PM
Ralph:
Aside from the boat tail or possible crank mods, what could be so secret as not to show??
Regards,
J.P.
