She/Her
BeauBlues's Avatar
Targa top problem, really annoying!!!
Basically I will be driving with the top on and if i hit any slight bump in the road or go in or out of a driveway from an angle, the clips no particular ones, but the ones in the front will pop off causing the top skin to not be connected with the frame. I tried adjusting the clips by pushing them back to make them grab more of the frame, but they wont go any further. Please help on this one. It scares the living daylights out of me when driving on the freeway and this happens.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 10-16-2004, 06:53 PM
HarryD's Avatar
I belive Pelican sells longer clips to deal with this issue. give them a call.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-16-2004, 07:07 PM
The longer clips are a jury-rig job instead of fixing the real problem which is that your top needs to be recovered. When the top is covered correctly the force of the top material being stretched tight pulls back on the targa frame. This causes the two main joints in the middle of the front and back of the top to over extend much like locking your knees. When that happens the clips won't pop off. You need to get the top fixed not just put a bandaid on it. If you are going to do the bandaid route then you can either use the long clips or just cut a piece of dowel or broom handle to force the front and back of the frame open a little wider like the top would do if it was in good shape.
I know from experience. My top would hardly stay on at all without the poll, then when I got the top back from Dan Petchel of Cars Inc from having it restored I didn't have a problem with the top popping off at 150 mph and it was really quiet because the front and rear seams folded down. It was a huge improvement. Only problem, getting it done right is not cheap, just shy of $1000, but hey, it's a Porsche, you expected that, right?
Old 10-16-2004, 07:52 PM
She/Her
BeauBlues's Avatar
I actually got the top re-skinned about 2 months ago, but the guy who did it couldnt get tight enough for it to be a good job. Plus the skin is also the domestic type, so when im doing some serious speeds, it will stretch and become saggy until it shinks back down. Could this problem be because it is the domestic type and not the german.
Gwyneth *she/her
1995 993 Guards Red
Old 10-16-2004, 08:01 PM
I'm getting ready to have mine reskinned but with the German material. I can't really complain since the vinyl I had put on almost ten yers ago has held up very well. But for the last couple of years it to has begun to ballon on long drives during the Texas summers. Oh and I too use a pole to keep the top tight against the clips.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 10-16-2004, 09:40 PM
She/Her
BeauBlues's Avatar
Can anyone show me a picture of a what you use as a pole to keep the top tight?
Gwyneth *she/her
1995 993 Guards Red
Old 10-16-2004, 09:51 PM
geof33's Avatar
masraum is right. The top was not done well. The arms should close with a bit of a "snap" almost feeling too tight. A bubble at speed is somewhat normal for these especially on hot days when the vinyl has some sun time. I don't think it matters if it is Dom or German. The install is the issue. And yes, the edges should face slightly down.
I'd get it redone. There is a guy here on the site that supposedly does a great job. I did my own... no big deal really if all you need to do is replace the basics... (burlap, foam and vinyl). It's another story if the whole top need to be redone. Typically they can be done for about 200.00 or so DIY....
A solution... get a hard top.
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 10-16-2004, 09:52 PM
limble's Avatar
I tried the longer clips and one side worked but not the other. I agree a new top probably is in order.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 10-16-2004, 09:55 PM
Any stick or piece of wood or other stiff object that you can cut just long enough to put some tension in between the two hinges of the front and back of the frame will do. cut some wood such that it is a tight fit and presses the two halves open tightly and put it where the red line is.
Old 10-17-2004, 03:41 AM
Designer King
Paulporsche's Avatar
I'm not familiar w/ these so forgive me if I'm offbase here. If that is visible from inside the car, perhaps a piece of 1" or 1 1/2" dia black ABS plumbing pipe would work. It would be lightweight and is already black.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-17-2004, 06:20 AM
Yes, it is visible. Anything stiff enough would work. I remember the first time that I heard about it was from someone on the Rennlist. He was using a piece of an old hockey stick that he had cut to length and then wrapped in black electricians tape.
I think 1 or 1.5" would be a bit large. From memory I think you'd want something in the .5-.75" size, but really anything that you could get to work would be fine.
Old 10-17-2004, 06:32 AM
