Accel dual sync distributor for EFI?
Supposedly Accel is making a distributor that outputs an RPM and cam signal for a 911 (it's in their catalog but there's no detail). Has anyone here seen or better yet used one?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I would rather be driving
Never seen that. what years is it for? single or twin plug?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
1971 Targa RS - Sold 1964 BMW 1800Ti 1969 BMW 2002 |
Super Moderator
Looks like you could fire a twin CDI type setup, but I can't quite tell from the picture if there are two posts per cylinder for spark plugs...
EDIT: The picture only shows 6 spark plug posts... But that may not be the end-all be-all picture...
I was thinking about using the Accel distributor for the crank and cam signal for the EFI and multi coil ignition and just put an aluminum cap where the cap and rotor would go. I have heard the signal from a distributor is not as precise as from an actual crank signal.
Somewhere in the Midwest
Wonder if it has advance (mech or electrial/prog)...
Gon fix it with me hammer
man that dfi team has some fugly cars
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
I currently have a dual sync distributor on order for a non Porsche project. I have discussed this with Rob at Force Fuel Injection. He is a great guy and easy to deal with. He sales multiple brand EFI setup which allows him to direct you to the best for application and not just to what he sales.
http://force-efi.com/ TEL 305-235-6160 Tell him I sent you since we were just discussing this in relation to Porsches too. He has sold this for Porsche applications in the past. He is much easier to deal with in getting information than Accel/DFI direct....trust me, I've had to do that several times.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
I run this distributor. I was the first or second to run it in a Porsche. It is meant to be ran with the Accel Gen 7. I have connections on any Accel stuff you will need. I run this in my 91 c2 turbo. The distributor is the crank and cam sensor in one. It is 6 plug post. You can run twin plug with a few mods. I will be the first that I know of to run twin plug with the Accel unit on a Porsche.
Eric |
Tried to post pics, but wont let me post the type they are
Eric Hood |
What happened to that Jaguar dist. cap fabriaction deal? The guy was going to make rotors as I recall?
Eric,
What format are the pics in? I can convert and post them if you need. Send them to sdubovsky@yahoo.com Lukesportsman, I've been burned by Force EFI. Last year I needed a Haltech ECU & harness. He had one "new". I made SURE to ask if it was new and the version of the ECU. I paid for next day shipping. The wire harness had been cut down (had been installed then simply cut out). Call him back: "Uh, yeah. That unit is new, but we make our own wiring harnesses and it may be a little shorter than the factories." BS! I found a new ECU locally (who knew they were there?) and force's was a factory harness w/ the coil and inj wires cut very short. The maps in the ecu were set up for something also. So, I got screwed for $70-100 shipping and lost out a valuable few days on my project. They are forever on my ****list... SMD |
Randy, Last I heard Aaron was doing a small production run to check tolerances. I am sure there are many of us waiting for them.
I am interested to know what has to be done for twin plug on this Accel dist. Do they supply an adaptor plate? What about cap and rotor? Strokher, can you give us a bit more detail on your setup? thanks
Eric:
Yes, running Gen VII. Well, I should say trying to run Gen VII. Just got the ECU back from Accel today after a diagnostic check. They couldn't repeat the issues I was seeing with my Unilight/Crane setup so I've decided to go with the Dual Sync Dizzy. Are you running Gen VII on your Porsche? What are your thoughts so far? Resolution? Feedback? Data logging? Thanks for your time. May I ask you follow up questions as I proceed with my install?
