RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
I need torque setting for head barrel nuts
I have spent the last 30 minutes "Searching" for the head stud (barrel nuts) torque setting.
I have over 1000 miles on a rebuilt motor and I want to check the head studs but I don't know what it should be.
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 10-18-2004, 05:31 PM
23-24 lbs.
206 637 4071
Old 10-18-2004, 05:34 PM
Unregistered
sammyg2's Avatar
If you have 1000 miles on the engine, that torque setting may not be accurate.
torque measurements are based on the threads being lubricated with a specified lubricant, dry threads require up to twice the torque to acieive the same stretch.
if the builder used anti-sieze you will still have the anti-galling properties but chances are the grease is burned away by now.
give it a shot and let us know how it turns out.
Old 10-18-2004, 06:04 PM
Somatic Negative Optimist
Gunter's Avatar
Find out if the rebuilder used lube and ask what torque he used.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-18-2004, 06:21 PM
Randy Webb's Avatar
With the ehat and corrosion involved, they will soon be welded on there anyway....
Old 10-18-2004, 06:28 PM
RickKlem's Avatar
I wan't to clearify that I'm talking about the Head bolt nuts. So is it still 24 lbs?
Rick
Old 10-19-2004, 04:13 AM
