Technical Question Regarding CIS w/Lambda
I have been reading both the Charles Probst's Bosch Fuel Injection & Engine Management & the Bentley Porsche 911 SC Service Manual to hopefully find an answer to my problem with no luck thus far. The 15° C temperature switch on the right front timing chain cover controls the CIS system from going from open loop to closed loop. Since I can measure a constant duty cycle at the three pin test connection, I realize that I am always in an open loop mode (the duty cycle is always at 50% when the engine is fully up to its normal operating temperature). I had removed the 15° C temperature switch and tested its operation in hot water and the switch closes as designed. When the switch closes it is supposed to provide a ground input to the Lambda control unit (lead number 7 on the harness) which should allow the system to go into closed loop operation. My mixture is indeed being controlled by the computer because I can both feel this control as well as see it on my Air / Fuel Ratio meter but the system (at idle) always remains at 50% duty cycle (open loop). What am I missing here? Why will the duty cycle not deviate from 50% - and yes, I realize that 50% is the target value but it appears that I am always there regarless of the position of 3mm basic mixture adjustment screw.
My goal is to address, identify, and correct this issue so simply unplugging the Oxygen Sensor is NOT the answer I am hoping to obtain.
Daryl G. 1981 911 SC - sold 06/29/12 |
"When the switch closes it is supposed to provide a ground input to the Lambda control unit (lead number 7 on the harness) which should allow the system to go into closed loop operation"
You have it backwards. The pin 7 grd causes the Lambda unit to enrichen the mixture for cold running. Once the engine warms, the switch opens which allows the O2 sensor to affect the mixture.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Loren,
I was reading the operation of the 15° C temperature switch in the Bentley manual and I realize that there are several mistakes in the book... I checked the switch and it works properly though I still have my problem. Your response suddenly made me think that there is another area I need to investigate - the actual wiring to the Lambda computer from the 15° C switch (the number 7 wire). If this wire is grounded and not sending the proper signal to the computer that could be the cause of my problem (at least that is how I rationalizing it now).
