89 Speedy's Avatar
Who makes the best oil temp gauge and
where do you guys suggest it be mounted in an 89 Carrerra? Thanks for your thoughts!
1989 911 Speedster
2006 Cayman S
No one ever said on their deathbed, "I should have been more practical."
Old 10-20-2004, 11:25 AM
Administrator
Jack Olsen's Avatar
What's wrong with the factory gauge? If you want numbers, you can backdate to the early sender/gauge.
Old 10-20-2004, 12:49 PM
89 Speedy's Avatar
I guess I need to know what temps the stick markers stand for. Which one is 180?
1989 911 Speedster
2006 Cayman S
Old 10-20-2004, 01:02 PM
ipapilot's Avatar
Maybe I'll be the first to respond here, but if you take a flashlight and look real closesly at the inside of the gauge you will see the temp designations written on the gauge. It is not visible without holding your head half sideways with the light, so check it out!
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 10-20-2004, 01:07 PM
89 Speedy's Avatar
Thanks, I'll have to check it out.
1989 911 Speedster
2006 Cayman S
Old 10-20-2004, 01:19 PM
Automotive Monomaniac
Emission's Avatar
Do what "JackOlsen" suggested. Get a replacement face. Cheap, easy, and effective update.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 10-20-2004, 01:27 PM
Bill Verburg's Avatar
It's not just a replacement face it' a replacement gauge. Actually the old style gauge w/ a matching sender. They both must be replaced.
Bill Verburg
Old 10-20-2004, 01:41 PM
Emission's Avatar
Yes, he's correct.
(You only need to replace the internals and sender, not the faceplate or trim ring.)
Old 10-20-2004, 01:45 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Originally posted by Emission
Yes, he's correct.
I just did this about a month ago. One of the best upgrages I have done to the car. And it is under $100!
1981 SC ROW Coupe
Old 10-20-2004, 02:50 PM
RETIRED
Joe Bob's Avatar
Noithing wrong with the itty bitty VDO gauges...put them in a location that can be seen at a quick glance. The one in the stock location is not really that handy...for me.
2012 ML350 3.0 Turbo Diesel
Old 10-20-2004, 04:27 PM
Virginia Rocks!
VaSteve's Avatar
Do not do this while driving. Ask me how I know.
Kidding!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 10-20-2004, 04:30 PM
The search button is your friend.....
I posted this several times for mid-80's gauges, this is accurate for your '89:
- lowest white block 60 degC ( 140F)
- next up white mark, 90 degC ( 194F)
- next white up, 120 degC ( 248 degF)
- lower part of next up red block, 150 degC ( 302F)
So...you can approximate this easily as 150/200/250/300
And this is even cheaper ( "zero") than the "best" $ spent by others !
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-21-2004, 04:30 AM
Go Speedracer, go!
--Wil
Agreed, but have you seen the late SC temp gages? They are a joke. No usefull lines on them, and the red zone starts at 302F, which I feel is WAY too hot. Here is a (bad) pic of the one that was in my car:
1981 SC ROW Coupe
Old 10-21-2004, 04:48 AM
I qualified my answer for which cars this recommendation applies to....
The original poster has an 89..so my answer applies to him..
Earlier SC's.....different gauge / different problem.....
But I'm sure some enterprising soul can come up with a similar rule-of-thumb answer for SC's ..
Wil
Wil Ferch
Old 10-21-2004, 06:03 AM
89 Speedy's Avatar
[QUOTE]Originally posted by Wil Ferch
[B]The search button is your friend.....
Now this is good info, thanks!!
1989 911 Speedster
2006 Cayman S
Old 10-21-2004, 10:45 AM
