Will program for food
Door handle disassembly help, please
I have 1 last piece to remove from my door handle, but I am stuck. Take a look in the picture. The red arrow points to the electric unlock modue (my best name guess). The green arrow points to a lip which prevents sliding the module up and I was weary about prying it off (plastic and probably brittle now). Any suggestions?
Thanks for any help... ![]()
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Not sure how to get it off, but that's the microswitch for the central locking system. Maybe this bump will catch someone who knows how to remove it.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
The manual says to "carefully pry" w/ a screwdriver here
Bill,
Thanks. Does you manual have a part number, just in case I snap this piece?
Oddly enough I can't find a part #, it's just called a microswitch. I am sure that a dealer can identify it, if it breaks. Best luck to you w/ it
I will proceed cautiously. Thanks Bill.
I hope is costs micro dollers, but somehow I am betting not.
Update,
The microswitch from the dealer is $95+... I took a SMALL screw driver and carefully pryed it off with out breaking it. Whew! Got every thing cleaned and now going to do the same for the drivers side. Then it is off to the powder coaters. The lever is pitted on one side so I think I will fill in the pits with bondo and sand smooth. Should look great. I'll post pics when done.
Thread Tools | |
Rate This Thread | |
