The passenger window on my 83 sc cab is stuck down in the bottom of the door and is off the regulator/ track. Which bolts can I remove or adjust to get it back into alignment. The regulator is above the glass and I can't get the glass back above without scratching the hell out of it.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Just a quick bump. Has anyone had to try and get the glass around the regulator ? The glass is all the way at the bottom of the door and the regulator is all the way up and can only go about 1/3 down before it binds and will blow out the glass if it goes any further. Any input would be much appreciated.
Wow,.... this is turning into my own personal favorite thread on the forum!! I was able to remove all the weather stripping and stick a long screwdriver down in there and push the glass up from the bottom and do some slight bending to get it around the regulator without having to remove it. After doing a forum search, I'm going to glue it into the channel with urethane adhesive after I do all the necessary adjustments so it doesn't happen again. Maybe do the driver window next?
