Green Skull 006
Jim Garfield's Avatar
Originally posted by klaucke
knowing a bit about VW bugs and that they are notorious for crumpling right above the jack slot in the rocker (and the same jack pad is used for bugs and 911's, the slot is the same) especially when a bit rusty, I am extremely skeptical about jacking a unibody car (namely my 911) from a point like this.
John, I wasn't suggesting jacking at the rocker but rather the 4 spots under the car recommended by the factory.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 10-26-2004, 01:00 PM
If you are going to jack on the engine, wouldn't the best place be not the sump plate but the spot basically under the lifting pad on top of the engine, which is way up near the front of the block? That's where the engine/transmission unit balances, in terms of weight distribution.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-26-2004, 01:27 PM
vash's Avatar
sherwood, i think klaucke is correct. your numbers are good with the car flat on the ground. to keep the math simple, if the car was 10 feet long, and the wheels are at the extreme ends, once the car is jacked up from the back to a 30 degree incline, the front wheels will see the 1500 and the rear would see 1000. gravity still pulls straight down, but now you have resultant forces acting. hope i just didnt give my statics professor a heart attack, cuz i am wrong
back on topic, i jack from the motor all the time, to protect things i use my folded haynes book as a cushion. no probs so far.
poof! gone
Old 10-26-2004, 01:50 PM
Vash,
Would you care to plot the weight supported by the engine as you lift from 1-30 degrees?
The point is, at the point where the rear wheels no longer touch the ground, the jack is supporting the rear end of the car and the lift point is an area under the crankcase. The fact one can't see any effect this has on an engine isn't material unless one is looking for observable bending. If the weight momentarily distorts the crankcase structure 0.010" or 0.030", you're not going to see that. Are those amounts cause for concern? As far as I know, Porsche did not design the crankcase to be a stressed member of the drivetrain, otherwise we could hang suspension pieces off of it.
As in my previous post, I said, "Any harmful side effects? Who knows. I'd rather not risk it."
I also said, "Do what you think is right."
Just wanted to get the numbers right.
Sherwood
Old 10-26-2004, 03:40 PM
Zeke's Avatar
Originally posted by vash
...........to protect things i use my folded haynes book as a cushion.
You think that much of it, eh?
Old 10-26-2004, 03:44 PM
vash's Avatar
yea, sherwood. i hear you. i just couldnt resist getting physics-acle on ya .
too bad i am only a civil engineer and not a mechanical. i only know about things that dont move, unless it is an earthquake. but without doubt, your theory is on the safer side.
cliff
p.s. dont tempt me on plotting the load on the motor as the angle increases. haha, that is only a simple excel worksheet away. haha. thanks sherwood.
poof! gone
Old 10-26-2004, 04:57 PM
Czar of C.R.A.P.
dfink's Avatar
Because I just love seeing how far a simple post can be taken may I ask which end of the car should be raised first the front or the rear. My problem is if I jack up the rear first I can't get the jack under the front. If I jack up the front can't get under the rear. Damn maybe that is why they put jack points on the side.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 10-26-2004, 05:39 PM
