Me like track days
Drove my 911 in very heavy rain yesterday while crossing Snoqualime Pass - water came out the circular footwell vents and made a soggy mess.....the engine ECU was almost swimming in water.
What the heck causes this?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
The drain may be partially plugged which allows the water to escape from the HVAC system in the front trunk. Or, your front hood gasket leaks.
I have the same problem, and just tend not to drive in heavy rain much.
Jason Keep Right Except to Pass! 2000 Audi S4 Quattro Non-Sunroof 1989 BMW M3 (sold 12/06) 1977 911S Wide Body 3.6 Varioram (sold 11/05) |
Me like track days
Yeah, it was the first time in heavy rain in 5 years -
You were probably going too fast with that new 3.6, causing a vacuum effect in the cabin sucking in the rainwater....
Really though, check that drain thingy at the bottom of the fan housing in your trunk. That's probably it. Seals are the next bet. Maybe this can be an excuse to get a flat hood with no fresh air intake?
