Question Does the starter always connect to the starter ring?
I've got a 74 915 connected to an 86 3.2L and was going to use the starter I got out of my 905. But i noticed that the starter didn't connect with the starter gear ring -- the sprocket didn't reach far enough into the bell housing.
I ordered a used starter for the 86 and the same problem exists. So i started to wonder whether the starter sprocket extends when the starter is engaged and only connects with the ring gear then, since i figured you wouldn't want the starter to always be spinning with the crankshaft. Or am I just making things up now?
thanks
arne
69 911E 3.2 (sold)
Old 11-07-2004, 10:17 AM
revelation!
206 637 4071
Old 11-07-2004, 11:09 AM
Designer King
Paulporsche's Avatar
Lightbulb
Now, be nice, JW. This (and reading these posts) is how those of us who are not mechanics learn this stuff.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-07-2004, 11:18 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I think what they are trying to say is NO it is not always connected to the starter ring. If it was I don't think it would last too long. There is a solenoid that shoots the starter gear out to contact the starter ring on the flywheel.
1981 SC ROW Coupe
Old 11-07-2004, 11:27 AM
beepbeep's Avatar
hihi...well at least you have two starters now
Yupp, the sprocket extends into ring gear when you operat the starter!
Thank you for your time,
Old 11-07-2004, 11:33 AM
sorry, i can get a tad sarcastic at times.
206 637 4071
Old 11-07-2004, 02:03 PM
