I've got a 74 915 connected to an 86 3.2L and was going to use the starter I got out of my 905. But i noticed that the starter didn't connect with the starter gear ring -- the sprocket didn't reach far enough into the bell housing.
I ordered a used starter for the 86 and the same problem exists. So i started to wonder whether the starter sprocket extends when the starter is engaged and only connects with the ring gear then, since i figured you wouldn't want the starter to always be spinning with the crankshaft. Or am I just making things up now? thanks
arne 69 911E 3.2 (sold) |
revelation!
Designer King
Now, be nice, JW. This (and reading these posts) is how those of us who are not mechanics learn this stuff.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-07-2004 at 11:20 AM.. |
Go Speedracer, go!
I think what they are trying to say is NO it is not always connected to the starter ring. If it was I don't think it would last too long. There is a solenoid that shoots the starter gear out to contact the starter ring on the flywheel.
1981 SC ROW Coupe |
hihi...well at least you have two starters now
![]() Yupp, the sprocket extends into ring gear when you operat the starter!
Thank you for your time, |
sorry, i can get a tad sarcastic at times.
