rdane's Avatar
What is your REAL power to weight ratio?
A little food for thought on the Subbies lovers. They might well be easier to drive in the short term
3.0 liter '79 SC
weight 2625# 14.34 lb/hp
factory 179hp SAE (actual at the wheels was 183hp on my 3.0)
0-60 mph, sec 6.3
1/4-mile, sec@mph 14.7 @ 92
STi
weight 3300# 13.75 lb/hp
300 hp (240 at the wheels) rated from a 20% loss
0-60 mph, sec 4.87
1/4-mile, sec@mph 13.23@104.6
964 C2
weight 2976# 12.4 hp/lb
250 factory (actual 240 at the wheels)
0-60 5.5
3.4 liter '79
weight 2400# 10.7 lb/hp
263 hp (223 at the wheels) rated from a 15% loss
0-60 mph, sub 5 sec (measured)
1/4-mile, sub 14 sec @ 100 (estimate)
BBII
weight 2400# 9.87 lb/hp
chipped 964 3.6
286 (243 measured at the wheels) rated at 15% loss
Old 11-07-2004, 11:22 AM
I admit to being a dummie some times what does BBII mean? Anyhow that looks impresive with the 3.4 I would bet you could get into the high 13s with that ratio. If you had it to do over would you go the 3.4 route?? I have been seriously considering that or the turbo route. Just asking
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-07-2004, 11:41 AM
rdane's Avatar
The fun and fast rebuilt 3.0s are 2400# and 195hp at the rear wheels with a compression bump, SSis and a set of 964 cams.
Makes them 12.3/1. Drop it to 2238 like Eric's and it is 11.47.
Not much to look forward to in fun cars when a SC sells for 10/15K these days
Whos driving a Very light SC?
Ben, BBII is Jack Olsen's car which many judge their own projects by. It is an early '70s body, lots of fiber glass with a 964 3.6 transplant.
If I were to do it again (same budget) I would go to a 3.4 Motronic single plug. More options and easier HP gains starting with Motronic and the 3.2. Basically you can get more for the buck starting with a 3.2.
The down side for me was I already had a very nice 3.0 that had some money into it and needed a valve job.
Old 11-07-2004, 11:51 AM
Good question!
REAL mass (weight) includes driver, too.
Old 11-07-2004, 12:07 PM
rdane's Avatar
Driver weight is also the easiest and most often changed.
Not really anything the factory would plug into a hp/weight calculation.
Call it a 200# driver.
3500# STi = 14.58
2600# 3.4 = 11.65
I would bet the driver in the STi I ran into weighted a good bit under 200#.
Old 11-07-2004, 12:31 PM
Grady Clay's Avatar
Guys,
REAL power-to-weight means measuring the rear wheel power on a dyno that you can somehow calibrate. I think this is very difficult on a chassis dyno. The only corrections should be the standard SAE adjustments for atmospheric conditions and those should be carefully measured.
The weight should be measured on calibrated scales and the cars in the same condition; say exactly so many gallons of fuel, driver in place or not, spare tire? Tool kit & jack?
The guys who do this professionally, where the calibration is traceable to NIST go to extreme lengths. Of course they never rely on a single measurement but apply statistical techniques on many samples.
Otherwise you are comparing oranges to tangerines.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-07-2004, 12:47 PM
Me like track days
Craig 930 RS's Avatar
My 79SC -- 2490 lbs (1/2 tank gas) , 280 hp at the wheels = 8.89 lb/hp
In the FWIW dept:
A very well driven (and slightly hp/track tire modified) STi was just a *tick* slower on the track acceleration-wise this past Friday 11/5 at Portland Intn'l.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-07-2004, 01:04 PM
rdane's Avatar
Thanks Grady I see your point. Just don't think the STi numbers are all that impressive compared to many of the cars on this board.
3.0 liter '79 SC
weight 2625# 1/4 tank of gas, 14.34 lb/hp
183rwhp on same dynojet
3.4 liter '79
weight 2400# 1/4 tank of gas, 10.7 lb/hp
223rwhp on same dynojet
3.6 liter '79
weight 2455# 1/4 tank of gas, 8.76 lb/hp
280 rwhp on the same dynojet
Giving a stock STi a huge benefit of the doubt this is what it still looks like.
STi
weight 3300#
300 hp @ crank
11lb/hp using the very optimistic crank numbers
Of course a "slightly modified STi" might be an STi like one here in the PNW that "on a 4WD dyno (was) putting 358hp to the wheels."
That would be a STi at 9.2lb/hp
But then we have Juan's little turbo play toy if anyone really wants to run up the numbers of subbie vs "street" 911
Old 11-07-2004, 02:24 PM
My 3.6 SC with me in it 2900lbs
270 hp 3.6
=10.74 lb/hp
1980 911SC Targa 3.6L
Old 11-07-2004, 02:35 PM
Me like track days
A stock STi produces amazing HP AND torque numbers.......but IMO is a complete pig compared to a 964 series and earlier 911 weight-wise.
The crux of comparing numbers *must* be power to weight.
Unfortunately comparing those numbers requires exactly what Dane states --- different vehicles on same dyno for a comparison.
I couldn't get a bead on what the HP increase the WRX had.
Had to be perhaps close to 400 hp to almost stay with 330hp and 2500 lbs.
Old 11-07-2004, 02:43 PM
WydRyd's Avatar
Weight ~2600lbs @ ~600 FWHP.
Weight will drop when I replace bulky OEM bumpers and 930 Tail.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-07-2004, 02:44 PM
rdane's Avatar
found these notes of trivia for the STi.
They can pump them up to 500 HP with factory add ons. They hold a total of 15.9 gallons of gas which relates to a total of 100# if the car is topped up.
Now we have a 3300# car (gas or no gas) and 500 hp with a very optimistic 20% drive train loss. That makes it 425 RWHP and 8.25lb/hp.
Hurray 40K$ STi beats 25 year old SC!
What kind of a 911 turbo will 40K buy you these days?
Old 11-07-2004, 02:55 PM
RETIRED
Joe Bob's Avatar
290 hp @ crank with a 2800 lbs cab....3.6 with a NBD chip and headers.....
2012 ML350 3.0 Turbo Diesel
Old 11-07-2004, 03:55 PM
Me like track days
MikeZ -
Cool! Can you post your dynamometer chart?
Old 11-07-2004, 04:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
SC with mildly upgraded 930 engine.
6.8 lb/HP (FWHP)
Old 11-07-2004, 07:01 PM
Me like track days
RarlyL8, can't access your site
Old 11-07-2004, 07:22 PM
pwd72s's Avatar
I'd say a lot depends on whether or not I'm in the car...
Old 11-07-2004, 08:24 PM
RallyJon's Avatar
Congratulations--you're convinced! I've never seen someone bench race so hard...
993 · 911 · STI · S4 · rally car
Old 11-07-2004, 10:48 PM
rdane's Avatar
Old 11-08-2004, 08:18 AM
RarlyL8's Avatar
Sorry, the site is down. I need to fix that........
Old 11-08-2004, 10:28 AM
