Difference between BOSCH DME ML3.1 and ML3.2
Hello,
I know that there are some specialists regarding Bosch Motronics on this board. So, can somebody tell me the difference between a Motronic (resp.DME) ML3.1 and a ML3.2 (or 3.3) ? Are there good infos somewhere in the web regarding the history of BOSCH motronics ? My guess is that the letters only say something about the principle (L, LH, ML, M...) and the numbers are just revisions. Somebody out there who can answer this ? Thanks in advance, Marco |
Marco:
FR Wilks probably knows more about Bosch DME's than anyone else I know. You might try contacting him. http://frwilk.com/944dme/ Tim
1986 911 Cab 2008 Audi A6 |
D-Jetronic, the D is short for Druck, the german word for pressure. Manifold pressure is measured to indicate engine load. L-Jetronic, the L is short for Luft, the german word for air. Air flow into the engine is measured with a movable vane (AFM). LH-Jetronic, the H is short for Heiss, the German word for hot. Air flow is measured with a hot wire.
K-Jetronic, the K is short for Kontinuerlich, the German word for continuous. Air flow is measured with a circular plate. KE-Jetronic is mechanical control with electronic modulation of the fuel mixture. ML is motronic with electronic control of everything and using an AFM (barndoor) for air measurement, etc. etc. Probst's book on fuel injection is good source for more info.
Nobody else on this issue ?
What do the numbers mean ? Greetings, Marco |
Shoot the Motronics expert an e-mail, Todd Knighton.
knighton@protomotive.com He'd be able to answer all your Motronics questions
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
The early Motronics as used on the Porsche 3.2 and BMWs were basically DME 1.X,
(35 pins). The DMEs as used on the 964 with on-borard-diagnostics was DME 2.X (55 pins), and on early 993s. The later 993 DME 3.1 (88 pins) had a mask ROM versus an EPROM. The 993 DME 3.2 (88 pins) used a flash memory (EEPROM) and an immobilizer code (alarm lockout). The final 993 with OBDII diagnostics used DME 5.X (88 pins) with flash memory which can be reprogrammed externally. The key is the Bosch number used (0 261 XXX YYY). The XXX denotes the DME type. Check out this web site (www.systemsc.com) on the Parts page for more info. Note: DME and Motronic are synonymous terms.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 11-11-2004 at 09:50 PM.. |
Speaking about a Carrera 3,2.
The BOSCH references the DME as a ML3.1. (But I have also seen some references as M1.0 and so) What is a ML3.1 ? Greetings, Marco |
"Speaking about a Carrera 3,2.
The BOSCH references the DME as a ML3.1." Buy some Porsche manuals & then read the Porsche manuals! The 993 manual (WKD 498 621) states the 993 uses DME 2.10.1 (page 2-1). The ONLY changes for the 911 3.2 DME from '84-'89 were EPROM changes; 1. early - 16K 2. '87 - 32K 3. '88 - '89 - 64K All 911 3.2 DMEs function the SAME and are therefore interchangeable.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 11-12-2004 at 08:00 AM.. |
Go to a BOSCH webpage and read the electronic parts catalogue !!!
BOSCH is referencing to it as ML3.1 ! I have a Porsche manual myself and there is no other information in there (not in Bentley, Porsche Reparaturleitafden or elsewhere) Is it not allowed to ask questions, buddy ? Greetings, Marco |
Your answers are here on this thread!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
