CIS injector seals
Folks (thanks in advance for the assistance - I always learn from these posts) I have checked through the threads for the last hour and got insight that pulling the injectors areca a real bear of a task. I have dismantled my CIS and I am trying to figure out if I need to replace the injector seals. My car was having the problem of misfiring only when the car warmed up so i went through everything and sumised it was a vacuum leak somewhere- (cold start fine etc) so I am resealing up the air box, installed the pop off valve, new intake runners, etc. My injectors seem fairly loose as I can turn them easily. I plan to dip soak them all in carb fluid to make sure they are clean. My question is - how can you tell if the injector seals are bad. IF one was bad how could you tell from the engines performance. Is there a way to check them while they are still in the induction runners. Thanks.
Old 11-11-2004, 02:24 AM
What year is your car?
If you drive a 1973.5 with CIS I can tell you all about those injector seals!
Regard
Bob
73.5T
Old 11-11-2004, 04:36 AM
Sorry about that - the car has a 77 2.7 CIS motor in it.
Old 11-11-2004, 11:34 AM
Dept store Quartermaster
lendaddy's Avatar
You mean the soft copper sealing rings? When mine leaked I went to my local autoparts store and bought a variety of soft copper brakeline seals (it's the same stuff for the same purpose). They were exact matches and sealed perfectly. I think they cost me $2 for a dozen or so.
Cornpoppin' Pony Soldier
Old 11-11-2004, 12:38 PM
Smart quod bastardus
fredmeister's Avatar
Yeah but the question is how do you know when the seals are bad and need replacing?
My 79 911SC has the plastic lines from the CIS distributor to each intake runner and they are able to turn easily at the runner connection. Does this mean they are bad?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-11-2004, 02:24 PM
diy83sc's Avatar
If the 77 CIS is the same as an 80 and 83, there are two orings. One for the injector which is smaller but thicker. When you pull the injector out, it will remain on the injector. Then there is a second oring around the injector receptor, sealing the gap between itself and the intake runner. Those you need to remove the intake runner to change because the are set in with a 3 point crimp. I may not have the terms right, but believe this is accurate.
When should you replace the orings? If you can wiggle the injector and see it moving in the receptor, it's time to replace them. You'll probably find they are rock hard by now. If you wiggle the injector and see the receptor moving, well then the receptor oring could use a changin' ... BTW, does anyone know of a good "temporary" sealnt to use on these?
Hope this helps.
Tony
Old 11-11-2004, 03:17 PM
Somatic Negative Optimist
Gunter's Avatar
Tony is right about there being two seals: I remember one thick O-ring to retain, and one smaller O-ring to seal. Bentley page 240-18 will help. I remember using a little WD-40 on the new O-rings to make installation easier. Be very careful when removing the injectors, they have to come straight out to avoid damage. It's a little tricky.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-11-2004, 03:33 PM
So you are saying that the receptor can be removed without destroying them? If they are crimped then how do you remove them without damaging the intake runner machined hole or the receptor?
I don't have the Bentley manual but will hope to find the procedure in the Porsche factory manuals, unless soemone can describe briefly the method to get them out of the intake in this post.
Thanks for the info so far everyone.......unfortunately I was really hoping to avoid removing the intake manifold to do this repair.
Old 11-11-2004, 03:52 PM
Gunter's Avatar
No need to remove the intake manifolds, the injectors will pop out. Soak the seals on the injectors with WD-40 before you try popping them out. Look at the injectors and decide where you would apply leverage so they are forced straight out. I remember disconnecting the fuel lines, and carefully applying leverage to the injectors by prying up on two sides. Do not pull on the fuel lines!
Old 11-11-2004, 04:12 PM
Just removed mine after finding sloppiness. 5 came out with the sleeves included, one sleeve stayed in the runner and is tight so i might leave it alone. I decided to order new sleeves too as the old o-rings are so hard, I dont know if i can get it off without destroying the sleeve. The injectors came out without much difficulty by using a leverage screwdriver handle under the pliers. I left the lines on so I wouldn't slip and mess up the threads on the injectors.
Anybody think it would be better to soak the injectors in a Techron/Feul mixture or just any carb cleaner?
SCott
Scott Clevenger
1989 BMW 325ix 190K
1981 911SC 110K miles
http://www.pelicanparts.com/gallery/clevy70911T/
Old 11-11-2004, 07:03 PM
lendaddy's Avatar
Just for the record I was talking about the screw-in injectors with a copper base gasket/washer.
Old 11-11-2004, 07:21 PM
Thanks for the many replies, been working late and hadn't had the time to respond. Below are pictures of the runners I have out (included a picture also of the ride, it is a 77 targa converted to look like a C2 convertible). I am presently soaking the injectors in techron. I can turn my injectors pretty easily. but do not have a lot of up and down play in all except one (I may decide to change the seal in this one). The upper seals do not seem cracked. The reason why I took apart my CIS/runners etc was because I having a miss after the car warmed up - say a half hour into driving. Start up fine etc. So I assumed after many frustrating months of trying to find a vacuum leak to take apart everything, clean it up, remove all the garbage emissions/smog stuff AAR etc, seal everything up in the airbox, add the pop off valve, replace all vacuum lines, intake manifold hoses etc. I am really queazy about attempting to pop out the injectors - as from looking through the boards some folks have had a real hard time taking them out - then broke the injectors. you know how it is with these motors on projects, anything you think will take you and hour usually takes you a day so I'm trying to be a little careful. I'm thinking about sealing the top of each with some permatex hi temp. Could someone show pics of their technique of pulling out these injectors the proper way as none of the books I have (101 porsche, haynes manual, CLYMER manual - shows how. - i think this would be an excellent additinal tech article to have on the site.
Old 11-17-2004, 02:32 AM
oops - forgot to post photos of the old 2.7 motor I'm trying to resurrect.
Old 11-17-2004, 02:34 AM
oneblueyedog's Avatar
To remove Injectors in car or out- take a open end wrench that is smaller in size than the wrenching head if the injector. Fit it under the wenching head between the manifold and the wrenching head. Between the wrench and the manifold insert a taped flat blade screwdriver and carefully pry up. The O rings stick after years and get hard. They'll either stay on the injector or in the manifold. If they stay in the manifold simply pry them out.
The injectors are very sturdy and the only things to worry about are kinking the plastic fuel lines and breaking the thermoplastic sleeves that protrude into the intake port.
Put them back in with some silicone direlectric grease smeared on the O ring with the ring on the injector. They'll push back in by hand into the manifolds (intake runners). They'll also pull back out much easier.
There is a seal between the sleeves and the runners but I have never tackled this in that they are held in place by peening.
78SC coupe, Silver Metallic
Old 11-17-2004, 04:18 AM
Gunter's Avatar
Try the above but spray some WD-40 on. The idea is to find a way to apply leverage up-wards so the injectors come straight out. Don't apply any side-way pressure, just straight up. Re-attach the lines hand-tight so that the nut protects the threads when you are prying.
Old 11-17-2004, 08:31 AM
After I pull the injectors and replace the seals, should they still be able to be turned freely or will everthing fit, tight smug and non moveable.
Old 11-17-2004, 10:41 AM
I replaced the sleeves and both o-rings. Mine still can be turned with some effort, but feels snug and is much better than before. I had to use a soft rubber piece and a rubber mallet to get a couple and the injectors back in. Why just a couple? Good question. Haven't started the car yet as I need to check for fuel leaks, having the entire CIS system out. That's tomorrow.
Interesting how many people have a 911 and an E30 Good taste, I suppose.
Scott Clevenger
1989 BMW 325ix 190K
Old 11-17-2004, 01:45 PM
E30's and 911's are timeless German Classic Design - no riceburning, changing the car look every year, trendy, britney spears stuff.
followed the great suggestions from the posts and got the injectors out using the method shown below, after soaking the seals with WD variant. The looser injector came out sleeve and all. Could this have been the source of my vacuume leak? Do I need to replace the sleeve now or should I put the same back in with a new upper seal with some permatex? - Thanks again in advance for the assistance. Sometimes I feel I'm in an AA meeting . Good to see that even after a contentious election folks can still hang out and be nice to each other. Long live the 911 - the ultimate uniter
Old 11-17-2004, 06:15 PM
That loose sleeve may be one of those factors of high Idle. Get some seals from out host. I imagine that the sleeve peens gave way. I think if you look and try to match the hammer marks that hold them in, it will work as original. I think there are three hit marks. I'd stay away from the permatex, but all of this is guessing. You've gone into a new area. Great photos!
Interesting post!
Old 11-17-2004, 06:55 PM
I decided to go ahead and replace the sleeves also. They are $3 each and getting the old 0-rings off the sleeves without damaging them would be difficult anyway.
Scott Clevenger
1989 BMW 325ix 190K
Old 11-18-2004, 04:27 AM
