2.59 or 65.78 mm is pretty damn close
regards |
Thank you very much for you answer racing!
Yes it's very very close !!! do you have the diameter of the hole exhaust ? |
Monday I will measure it for you
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Yes if you can. I really appreciate. I think its the same size for 86. But i m not sure. I will try to make the tool :-) :-)
I wait you. Thank you very much. |
it s nice with new studs !!!
French Import
One of them had to be oversized as the hole was too big to fix with an 8mm Time-sert so I went with a 10mm instead. It's the one with the nut on it.
I'll go measure in a moment and post the dimensions.
Cool !! Times insert could be really good ! Thanks gilles
French Import
Thanks a lot !
2.7 is 32 mm SC ?? 3.2 is 41.1 mm Maybe 3,2 is not equal to SC
![]() Maybe, port = what i need ? |
65,9 mm and 35 mm
i will go to 6.8 mm or 7 mm for 8 125 stud
