I deleted mine as well. Looks great without it!
Jeff Randall
'90 Carrera 4
'79 911SC
PCA NW Region Member
SCWDP Member - Muhahahahaha
Old 12-23-2004, 08:36 AM
CBRacerX's Avatar
catca -
BC is not NJ - you need AC in a Daily Driver.
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 12-23-2004, 10:18 AM
randywebb's Avatar
Pretty funny - I bought one on eBay to add to my car. The wt. is low - should be data in my spreadsheet on Thom's light wt. page.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-23-2004, 01:12 PM
Alii&Maui
Jesset100's Avatar
Took mine out today. That one screw that is hidden is a pain to get to but I pried the carpet up and took the screw out. Wiggling the console out the plastic tab that I fought so hard to get the screw off got caught under the carpet and broke. Oh well. I too followed the wires and clipped them to where you can't see them. In the smugglers box their was a relay that I took off and clipped those wires except for two wires, a black one and a red/white one. Those two were hot and I didn't want to mess with hot wires so I just taped them up and tie wraped them so their out of the way. Come to think of it the red/white is always hot and the black is hot when the ignition switch is turned on, maybe I could use these for let say a CD changer or maybe an amp or something.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 12-23-2004, 02:16 PM
Originally Posted by CBRacerX View Post
I've got the late Carrara console with AC controls and Rear Defog, Hazard Lights switches. I am keeping AC but would like to loose the console. Anyone done this yet, keeping everything functional?
Chris
Totally doable...
I just deleted the center console in my 1987 Carrera and it appears that I have quite a bit of wire to relocate switches to the dash. Since I am deleting the radio, I will probably locate the hazard, the defrost, and the central locking to the radio location. Plenty of wire to go there. The A/C will most likely be deleted as well. A bit of of a PITA getting everything separated in the console without destroying the parts or cutting wire. I did cut the 4 wires to the central locking switch in order to get it out of the console, but then found a disconnect under the carpet near the accelerator pedal afterwards. Small repair could have been avioided. Before:
During:
After photo to follow.
1987 911 Guards Red Carrera (current project)
1988 BMW 325 iS (sold)
1989 325iX (winter blaster)
2013 VW Jetta TDI (civilized touring car)
1991 Saab SPG (sold)
Old 05-28-2013, 02:05 AM
fred cook's Avatar
Console delete
Here is a picture of my SC with the console removed. I made a bracket and mounted the a/c switches in the nook where the ashtray used to live. Hope this helps.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-28-2013, 04:03 AM
I removed mine a few weekends ago. Makes the drivers area feel a lot more spacious. Highly recommended. RS door cards next.
Old 05-28-2013, 04:23 AM
