MSD HI-Vibration coil and Ballast resistor?
Hey again!
I just got my MSD "HI-Vibration" and MSD ballast resistor today! I have a stock ignition system in the 1975 911. I wanted to know if I need to use the MSD ballast resistor with the new MSD Hi-Vibration coil? Or do I just swap out the old leaking Bosch coil with MSD coil w/o ballast resistor? I see in previous posts that some people use ballast resistor and some don't use them. Thanks, Rpettway
1975 Porsche 911 "We screw, We Nut, We Bolt!" |
The way I understood a previous post by Warren, the coil alone is compatable with the Bosch CD ingition unit...
I just read the MSD papers. The ballast resistor is for current triggered tachs which we don't have. Or engine run-on which you don't have. You have stock ignition which means you have a Bosch or permatune CDI.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Oh I was told that the resistor is to reduce the voltage to extend point life.
Mike
1972 911T Targa 1994 Volvo 850 Wagon 1988 BMW 635 CSi |
you should have stock Bosch or Permatune CD box on your drivers side engine compartment electric panel.. make sure you have this unit installed..
ohhh.. I scrambled who asked the question I answered.. maybe a '72 didn't have a CD.. maybe it has the old induction coil ignition? If so then a resistor is needed.
so sorry
Ron...'72 is Bosch CD...
"so sorry" ..I take that back
