Where to test WUR control pressure?
CP test
Where is the control pressure for the WUR tested. I can't figure this out, as the cp for cold engine is 0,5 bar and warm engine 3,7 bar. It cant be behind the wur as the prseeure would be high on a cold engine prabably more than 0,5 bar. When its warm the pressure behind the WUR will be lower than for cold engine. What am I missing here? Marius
M Oosthuizen '87 Carrera '80 SC Sold |
Designer King
Marius,
You have to hook up your gauge in the line that runs from the top center of the fuel distributor to the WUR. There is also a procedure for jumping the fuel pump so you can get pressure without the car running. The Bentley manual has this in section 240 10-15. If you search you will find others' comments on procedures. I think someone made up a diagram on hookup & gauge location.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
