v9ff's Avatar
SUB-FRAME CONNECTOR ON A 911
Has anyone welded sub-frame connectors onto their 911?
I was talking to some racer dudes and they've all done it. Perhaps their cars need it and not our 911.
So I was at my mechanics shop and he had an NSX on the lift and I took a picture of how they did it. Basically, they welded two bars along the sides then and "X" to connect them. They used 1 inch by 2 inch bars so you only lose an inch of ground clearance.
The picture below should help.
Old 11-16-2004, 09:19 AM
Senior Member
Steve,
My first thought would be that if it was really needed, that the Porsche factory would have done it on their race cars.
Joe a
Old 11-16-2004, 09:50 AM
project935's Avatar
Coupes shouldn't need it if they have a 6-or-more point cage. I could see it benefiting a car that doesn't have a cage ... but not as good a job as a cage could do.
Targa's and Cab's would benefit the most.
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 11-16-2004, 09:53 AM
v9ff's Avatar
Originally posted by Joeaksa
Steve,
Joe a
True... so does anyone know what sort of extra bracing the factory did on their race cars? Was a full cage the only thing?
Old 11-16-2004, 09:54 AM
I think usually when they add a full cage they add bracing sorta like that but inside the car not outside. It seems the full cage like we might buy ready made is not as extensive as what ends up in a real racecar.
Old 11-16-2004, 10:48 AM
project935's Avatar
I haven't heard of Porsche adding additional bracing to a chassis - other than adding more tubes here and there to the cage. Most early cages were Al to save weight ... that would never fly with today's racing regs.
A fair amount of chassis stiffness can be had by stitch welding the bodypanel edges ... ie. not relying on the spotwelds alone. But that is more for full-prep race cars. Would also make panel replacement fun ...
I like the X underbody connectors as long as the car isn't too low already. You could probably talk Thom into trying it
Project935
Gruppe B #101
What's next?
Old 11-16-2004, 12:07 PM
Senior Member
935,
Was at Patrick Motorsports a while ago and they welded each and every seam, not just the spot welding. Asked about it and they said that it really stiffened up the car and did not add that much weight.
Joe A
Old 11-19-2004, 03:54 PM
