moosthuizen's Avatar
Where to test WUR control pressure?
CP test
Where is the control pressure for the WUR tested. I can't figure this out, as the cp for cold engine is 0,5 bar and warm engine 3,7 bar. It cant be behind the wur as the prseeure would be high on a cold engine prabably more than 0,5 bar. When its warm the pressure behind the WUR will be lower than for cold engine.
What am I missing here?
Marius
M Oosthuizen
'87 Carrera
'80 SC Sold
Old 11-18-2004, 11:47 PM
Designer King
Paulporsche's Avatar
Marius,
You have to hook up your gauge in the line that runs from the top center of the fuel distributor to the WUR. There is also a procedure for jumping the fuel pump so you can get pressure without the car running. The Bentley manual has this in section 240 10-15.
If you search you will find others' comments on procedures. I think someone made up a diagram on hookup & gauge location.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-19-2004, 06:09 AM
