Bez Bez is offline
Help w/ option codes
I need some help deciphering this sticker on my 85 cab (ROW turbolook). Shouldn't there be more option codes listed? Appreciate the help.
Old 11-17-2004, 08:56 PM
Bez Bez is offline
I'm not big into bumps (especially after a goose-egg on the replies), but I could use some help on this.
My recently purchased car is a factory turbo look (brakes, suspension, fenders), but it doesn't look like the m491 is listed on this sticker. Any recommendations on how I can investigate? Since its an ROW car, I presume I'd need to chase down an Cert of Auth from Germany, not PCNA. Thanks.
'71 911E Targa rebuild project, '82 SC, '85 911 M491 cab, '90 C4, '85 911 cab, '77 911 C3 (all sold )
Old 11-19-2004, 09:43 AM
Eric Coffey's Avatar
Hmmmm, what year?
Are you absolutlely sure it's a FACTORY turbo-look?
Does the VIN on the hood sticker match the rest of the car (could have had the hood replaced at some point)?
I would also check the red maintenance manual (if you still have the original), as there is a VIN/options sticker in there as well.
Good luck!
Old 11-19-2004, 11:45 AM
Bez Bez is offline
VINs match and indicate car is an 1985; engine # indicates 1985 euro spec 231 hp motor. Car has the other turbo-look features, not just welded fenders. Had ppi done at S-Car-Go in Marin (Porsche specialist) and they indicated car is factory tl. I don't have original manual (got some US version manuals with it though). Reason for asking is I heard that some ROW TLs were made without the option code documentation and I wasn't sure if I had one...or even if the story is legit.
Old 11-19-2004, 03:52 PM
Well, I have no more useful info, but lets see some pics!
Old 11-19-2004, 04:21 PM
