LM-1 as poor mans windtunnel
Hi,
I saw a lot of discussions on this board about the effects of different tails and so on, specially with respect to downforce. Here's a suggestion how to datalog downforce while driving. Needed: 2 stroke-pots for front and rear car with swaybars front and rear LM-1 with RPM converter or Auxbox. Fabricate a little clamp-on lever to clamp to the center of the swaybar. The lever will be connected to one side of the stroke-pot. Other side mounted to chassis. Supply stroke pots with 5V. Mount them so that with the car at rest they are about halfway pushed in. To calibrate, put the car on a level surface. Load the rear or front up with 50# sandbags positioned over the axles, one at a time and note the stroke-pot voltage as the car sinks into its suspension. You can do that with LogWorks also Then enter the voltage/# equivalents in a LogWorks lookup table. Do your test-drive on a smooth track. With RPMs logged and known gear you can calculate speed and directly look up downforce vs. speed, using the cars suspension as the force-measuring spring. Use the LogWorks smoothing function to average out the effects of uneven surfaces. Measure at constant speeds as acceleration or braking loads the cars rear or front. Regards, Klaus |
Klaus, great idea!
It seems that anything that can be reliably measured with a potentiometer is susceptible to measurement and logging. I suppose driver's heartbeat and body temperature are feasible too.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
LM-1 is a sort of sensor I am quessing can you tell me what it does?
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
Hi John,
Actually I want to go a step further. With the LMA-3 you can log accelleration with variable sensitivity. Set the sensitivity to 0.25g. Then drive the car on a level track (no wind) up to a certain speed and drop the clutch. Datalog the coast-down. From that the coast-down speed profile can be calculated. A second order polynomial function can be fitted to this coastdown log. The polynomial has the form: A*v^2 + B*v + C. The A constant is your aerodynamic coeff (frontal area * ca) . The B constant is gearbox drag coeff (which is roughly proportional to speed) and C is rolling resistance. This should give additional info about aerodynamics. I am adding all the calculations and curve fitting to the next LogWorks version. Of course drivers heartbeat and temp can be logged as well. Just use the appropriate sensors. But I don't want to elaborate Regards, Klaus |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Author of "101 Projects"
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
