				Rebuilding cailpers?
			If I just rebuild my calipers and I put them back on my car and they are not working correctly can I rebuild them again without damaging the new seals?
	Matthew “Sometimes the questions are complicated and the answers are simple.”  |
			 Formerly bb80sc
			Matthew, can you define "not working properly"?  You may be experiencing issues that are inherent after a fresh rebuild.
			-B
	Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited  |
			Matthew - Yes, I've pulled them apart a 2nd time w/o problem if you are sure to lube up the pistons when re-installing. Your problem may be the rubber flexible lines and not the caliper; that was my experience.....G'luck
	Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles  |
			You shouldn't have to rebuild them again after doing it the first time unless you didn't put the pistons in with the notch at the correct 20* angle.  If they aren't working then either something else is bad or you need to bleed them.
	Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa    SOLD 2004 - gone but not forgotten
			When my rebuilt calipers went back onto the car, I was somewhat concerned about the pedal being very solid, but initially travelling slightly farther than I thought it should.  If I let up on the pedal and pressed down again, it was at a slightly higher level that I deemed as correct.  My buddy, who has been a factory Porsche tech for 22 years, told me to drive the car and that issue will dissapear in a few days.  When I asked him the reason, he spoke over my head ( which isn't too difficult) so I trusted him.  Sure enough, the pedal was perfect after a few days.
	'82 911 SC  |
			I did it! Yahoo! Thanks guys I rebuild them a second time things went very well and everything is a-okay
