Need HPX ignition settings help
I just installed a electromotive HPX crank fire ignition on my 69'
911 'E' motor which is stock except for 40 webers and headers.
Since I never ran one of these kits what are the best settings?
The instructions call for 12 degrees initial,24 degrees @ 3000
and -2 degrees at 8000. Are these settings OK for this motor.
This will only be run on the street.
Old 11-30-2004, 04:25 AM
Super Moderator
cstreit's Avatar
You can initially mimic your stock advance curve, however Richard Clewett claims that engines with the higher 3k RPM advance show more torque. I have a 3.0L but it's twin plugged and I use 8, +21, and +2. However a single plug motor will have more advance.
I think 12 is still a bit high for initial settings despite what EM says.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-30-2004, 06:04 AM
304065's Avatar
I don't understand the nomenclature evidently.
The idle timing for my '71 2.2 E is 4 ATDC. The advance at 6000 RPM is 35 BTDC.
Are you fellas describing some points on a curve or something?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-30-2004, 08:59 AM
chuckw951's Avatar
Here is another thread to review (re: settings for HPX on a 3.0)
Settings for Electromotive HPX ignition
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 11-30-2004, 10:55 AM
