difference between 2.2L & 2.4L P&C ?
all;
can someone tell me the difference between the 2.2L & 2.4(MFI) P&C. thanks! jerry |
fancytown
2.2L are higher compression. Comparing the two, you'll see a slightly higher "dome" on the 2.2L. To compensate for this, the valve pockets will be cut slightly deeper.
This is why some people, like myself, rebuild their 2.4L's with 2.2L pistons.
all cars sold. |
i'm starting to get it. higher CR, but no change in displacement. is it possible to use 2.2L E pistons in 2.4L CIS cast iron cylinders ?
thanks again best jerry
Unclear on the concept ? Let's see if I can help. 1) You are NOT in the "fast lane" and... 2) You are NOT going "fast enough". **News Flash** You're in the Passing Lane. Any questions ? |
up-fixing der car(ma)
It is if they fit correctly....
