A/C Switch Bypass - Ideas?
Well, I've now twice buggered-up that funky electro-mechanical temperature control diaphragm "switch" for the A/C while trying to install it. So, I'm considering just bypassing the darned thing.
Since the A/C, even with upgrades, is unlikely to actually produce more cold than I want, I really don't care about the temperature control aspect of the thing. So I was thinking, why not just install a switch (maybe a rotary switch with the stock knob mounted on it). I could then stick a thermostatic switch at about 40 degrees in the evaporator core so I don't freeze the evaporator. Any ideas? Anyone know where I can get a closed-above-40 thermostatic switch?
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 12-06-2004, 06:56 AM
Phil:
My switch was also buggered up, so I tried putting a simple on-off switch in like you suggested. The problem I encountered was the evaporator would freeze up.
I ended up finding a generic switch identical to my original, but with a little longer capillary tube for around $50.
Tim
1986 911 Cab
2008 Audi A6
Old 12-06-2004, 10:17 AM
Exactly my concern, which is why I would use an electrical switch in the evaporator that would shut off the A/C at about 40 F.
Where did you find your replacement switch?
Phil
K27 B+B 1 Bar
shaved gutters
Old 12-06-2004, 10:41 AM
I found it at an automotive A/C shop. I think it was made for an RV air conditioner.
Tim
1986 911 Cab
2008 Audi A6
Old 12-06-2004, 11:00 AM
