Calling all grease experts...
I'm getting ready to do a clutch/flywheel upgrade on my '95 993, and I'm wondering what type of grease would be best to use on the guide tube, pilot bearing, and throwout bearing.
I see Warren in the past said he uses Moly EP, which is good enough for me.
So, should I order some Swepco 101, or would one of these (which I have sitting on my shelf already) be OK:
1 - Valvoline Synpower grease - for CVs, bearings etc. "moly-fortified".
2 - CRC Industries Sta-Lube EP Moly CV Grease
I'm probably overthinking this, but I want to be sure I get it right the first time.
Thanks!
Colin
Old 12-11-2004, 01:04 PM
Any heavy grease with molybdenum will be fine. Remember less is more
Chris
Old 12-11-2004, 01:10 PM
Hey Colin,
I don't know what tranny you have but if it has the vertical shaft in the bellhousing you might want to take it apart and clean the old grease out and relube. That makes a huge diff in the clutch feel.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-11-2004, 03:00 PM
I believe JW posted some dealer high temp grease for the throwout brg/tranny shaft.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-11-2004, 03:31 PM
JW says,
" porsche sells optimoly high pressure grease #000.043.024.00. it's for things like pilot bearings and clutch cross-shaft bearings that may never see grease again."
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-11-2004, 03:43 PM
Use the Porsche grease. Never grease the release bearing guide tube if using the factory clutch release bearing. The bearing will have a plastic inner liner with a split in it, grease causes stickiness. This is as the factory technical bulletin. Always grease the end of the slave cylinder rod, use an anti-seize or similar grease.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-11-2004, 03:47 PM
Diss Member
Quicksilver's Avatar
Bosch distributer grease. Very high temperature and it stays in place at high temperature. Pelican lists it.
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-12-2004, 02:27 AM
I should really learn to read someday
Good luck on the clutch
Dean
Dean
Old 12-12-2004, 05:45 AM
randywebb's Avatar
BTW, Grady has neat little trick - cut a groove in the clutch tube to let any leaks drain out. Search on my name, Grady Clay and transmission and (probably) 901.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-12-2004, 12:15 PM
Thanks everyone. I guess I'll get the special Porsche grease.
I'm upgrading to the RS/Lightweight single-mass flywheel, so it's all factory parts.
Britwrench, you saved me from making a mistake on the guide tube - thanks for posting.
Old 12-12-2004, 12:48 PM
