Euro Carrera 3.0 specifications?
What were the original specifications of the Euro Carrera 3.0?
Was the entire body fully galvanised?; Were the rear flares the same as '73RS or SC/3.2? What brake rotors and calipers did it have? 15 inch or 16 inch wheels?; What material were the valve guides (early copper alloy or later silicone bronze)?, Was the transmission casing made of magnesium or later aluminum?; 4 or 5 speed?; 1 or 2 batteries? etc etc
TIA
Old 12-16-2004, 11:13 AM
1. Fully Galvanized
2.SC style flares on back
3. 15 inch or 16inch depending on order
4.engine was basically an SC motor with slightly "hotter" cams and different valve timing
5.5-spd aluminum 915
6. 1 battery
7. pop out windows on coupes
8. snorkel headlight washers
9. I believe slightly thicker sway bars
10.brakes are m caliper like SC's
Let Noah chime in, as he knows more than anybody I have talked to about Carrera 3's. I do have the factory sales brochure, but it is in German.
Alan Poh
'77 Carrera 3.0
Old 12-16-2004, 11:23 AM
Irrationally exuberant
ChrisBennet's Avatar
A few more crumbs...
Internally the motor was different from an SC. It had a 2.7 crank with a 6 bolt flywheel vs the SC's 9 bolt flywheel.
The camshafts were the same part number as the '78-'81 SC.
The 3 C3 transmissions I've worked on were magnesium but I think Noah has an aluminum one.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-16-2004, 11:38 AM
The engine block was not the SC block (930 3.3), but the 930 3.0 block, which is much lighter.
The popout windows were only on the '76, not the '77
The Magnesium gearbox was slowly phased out during the 2 years production run.
The '76 did not have the power assist brakes, or the clutch helper spring.
Old 12-16-2004, 11:50 AM
What's the weight difference between 930 3.0 block and the 2.7 magnesium block?
I'm glad!
Now, what about brake rotors? Same as 73RS?
Old 12-16-2004, 11:58 AM
I don't think the redline is 7000 rpm, rather 6800. Anything close to 7000 with CIS cams is a bent valve waiting to happen.
I know of a couple Mg gearboxes pushing 200K miles without casing trouble, the worries are overrated.
I have no idea of the weight difference between a 2.7 mag case and a 3.o alu. case.
Old 12-16-2004, 12:04 PM
Noah, stupid question: have you indeed seen 7K on your car? mine used to cut at 6800. The new engine I never use above 6500, as the cams were retimed in favor of lower rev power.
Old 12-16-2004, 12:19 PM
The reason I am asking is because I thought like you did, and I asked my mechanic to "give me back" the 200 rpm I was missing. He was adamant that I would destroy the engine if I flirted with 7K for any time with that engine. That is why he adjusted the cams a little differently on the new engine, giving me a good pull from 3500 instead of 4000 like the old (bombed) engine.
Old 12-16-2004, 12:27 PM
AZ1977911's Avatar
Hi All,
Mine hits 7K fairly often... Rev limiter functions only occasionally. My tach could be off. 40K miles and no serious problem since I've owned it. It aint stock though. (3.2 Big Bore kit)
Greg
77 Carrera 3
Old 12-16-2004, 01:08 PM
Bill Verburg's Avatar
Depends on the year '76 or '77
The other responses have covered the bases but I'll just chime in any way
Except for the roof on early '76
SC
282.5x20 & 290x20 same as 2.7 thru SC
Cu alloy
My '76 was Mg. the Al was phased in later in '77
4 or 5 speed?
4 spd was standard 5 optional
1 battery most of the car was as on the later SCs
The redline starts at 6800
Bill Verburg
Old 12-16-2004, 01:24 PM
drag racing the short bus
dd74's Avatar
Hmmm...I once heard the typical 911 valvetrain is good up to 7300 RPM. I'm not willing to try, though.
The Terror of Tiny Town
Old 12-16-2004, 01:30 PM
Same as Noah, with pop-out windows and aluminum gear box.
Alan Poh
'77 Carrera 3.0 #499
Old 12-16-2004, 02:18 PM
Hald's Avatar
Pop-out windows & magnesium gear box... #720
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 12-16-2004, 03:57 PM
OZCarrera3's Avatar
How can I tell what type of box I have? From Noah's post I should have a mag box.
Mine has pop-out windows, chassis # 00825 and was built 08/76.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 12-16-2004, 05:19 PM
OZCarrera3's Avatar
Thanks Noah. Hey, why would my chassis number be higher than you guys, yet earlier build date? Note, I have had my engine and chassis numbers verified Porsche Australia.
Are you guys quoting a year model (i.e. built '76 for '77 year model)?
Sheldon
'07 BMW 335i
Old 12-16-2004, 06:09 PM
AZ1977911's Avatar
Noah,
Mine was 9117610035, registered 1977 USA (federalized) 19&& as well.
As per COA...
Greg
Old 12-16-2004, 07:52 PM
AZ1977911's Avatar
Ooops! 1977... FWIW not 19&&
Old 12-16-2004, 07:53 PM
Jubbie's Avatar
Odd on the Na filled valves. My 77' C3 engine had the dots in the middle of the exhaust valves, so I figure that they must be sodium filled. The PO may have changed them out. What did the 930 of the same vintage use exhaust valve wise?
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 12-16-2004, 08:26 PM
OZCarrera3's Avatar
Speaking of the magnesium cased gearboxes, I've been told that they can have problems on the track due to heat buildup etc. Has anyone had a failure? What happened? Is it a case of if you use them on the track "it will happen" or "may happen"?
Sheldon
'07 BMW 335i
Old 12-16-2004, 08:37 PM
The C3 did not have Na filled valves on either intake or exhaust. The 930 from that period did have Na in the exhausts.
Bill Verburg
Old 12-16-2004, 08:41 PM
