What is a good oil change interval for a 1989 Carrera 3.2 Daily Driver?
3000 miles? 5000 miles?
IIRC, my manual says 15000 miles (7500 miles for turbos), but that seems awfully long. |
I would say 5000 miles, which is what I do.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
You have to change the oil?
Alan Jackson 77 911S 3.2 |
Yes, you must change the oil and anti-freeze.
But seriously folks, the Porsche engine longetivity is a function of the oil, i.e. change the oil regularly and the engine will last forever (Unless a head stud breaks or the valve guides wear out). For the $25.00 or so it costs to change the oil and filter, I would not go longer than 5000 miles. Less if most of your driving is stop and go or short trips.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 12-21-2004 at 01:48 PM.. |
Does dirty oil have anything to do with broken head studs or worn valve guides?
Those are the things that seem to be the leading cause of 911 engines having to come apart. Anyways, I personally go 5000-7500 miles in my daily drivers, or once per year. With a 911, with a huge oil filter and twice the capacity of most other cars, it would seem that's pretty conservative for a normal street driven 911. |
Luckily, us REAL Porsche drivers in the REAL world have to switch to Winter oil and so have to do two mandatory oil changes per year.
Beethoven '88 911 Coupe |
If you Carrera burns enough oil, then keeping it topped off should eventually cycle out all the bad oil, right?
My Carrera never went more than 3k miles without new dino oil and filter. 993 gets new Mobil 1 and filters every 5k or after each track event, whichever comes first. I don't care what the manual says. Preventative maint. is my mantra.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Service intervals will depend on service severity. The most severe use for most drivers is lots of short trips, where the engine and oil never get really hot for long periods of time. For that sort of use 3k mi max.
Just check the level often and if the oil looks cruddy change it. I do it at least every 5k. It is easy to remember and i could not multiply by 3 too well
![]() Oil is cheap, engines are not. alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Every 5K oil and filter sounds good for all around - dino or synthetic.
With good synthetics and mostly highway miles, you could probably get away with a filter every 3500 and oil every 7000.
Project935 Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06 Gruppe B #101 What's next? |
