Licensed User
Shuie's Avatar
Scored a large displacement MFI setup
If this is a dream, please don't wake me up
What do you guys think this was from originally?
Intake port orifice measures 39mm, the top of stacks are 43mm. Everything was covered in dust, but it cleaned up nicely. The pump turns over smoothly by hand and the throttle plates all move smoothly and freely.
I know that the '73S shared some part numbers with the 2.7 and 3.0 RS cars on the MFI setups. Is there anyway to tell if this came off of a 3.0 RS without disassembling the pump and looking at the spacecam? Can you guys tell from the serial numbers?
TIA
Old 12-18-2004, 01:42 PM
Grady Clay's Avatar
WOW - Good for you!
In Bosch-speak 0408 126 019 is a '72-'73 2.7SC MFI Pump!
In Porsche-speak that is a 2.7RS. The Porsche part number is 911.110.254.00.
Judging by the casting date (51/72) and the serial number (32302158), I would speculate it is a '73 2.7 911RS. Someone with access to the numbers can confirm. I suppose it could be a 3.0.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-18-2004, 01:49 PM
Holy **** Batman!!
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 12-18-2004, 02:19 PM
Bird. It's the word...
Fishcop's Avatar
Tell us the story then!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 12-18-2004, 02:39 PM
Licensed User
Shuie's Avatar
Thanks everyone!
So the big question is, can I put this on my 3.2 without re-camming the pump?
You guys would never believe me. This was luckier than finding my 3.2 Max Moritz motor. Oh well, I'll take luck anyday
Old 12-18-2004, 02:43 PM
Cornpanzer's Avatar
Yes, lets hear the story!!
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 12-18-2004, 02:44 PM
Grady Clay's Avatar
Sherman,
I'm off to the Pelican Gathering of the Flock.
The answer is a qualified "yes." I'll e-mail you tomorrow.
I just think you saved this from a dumpster.
Best,
Grady
Old 12-18-2004, 03:03 PM
Elombard's Avatar
Sweet, you realize you have to drill the heads to add MFI to a later motor.....
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-18-2004, 03:34 PM
Licensed User
Shuie's Avatar
thanks Grady, I appreciate the help.
Licensed User
Shuie's Avatar
Yep, thats the easy part. The hard part is the stacks and throttle bodies. Im still struggling with the 4 bearing cam towers and cams, but I think im making it more difficult than it really is.
The only bad thing about this is that I already have a fresh set of stock smallport SC heads from EBS with all new valves, guides, springs, and retainers that do not have the right port size for the RS throttle bodies.
I didnt want to change anything too drastically on this motor since it ran very well with the small port heads, GE40 cams, and webers. I hope that going to the bigger ports, and MFI doesnt throw off what Ive been told was already a great motor.
Old 12-18-2004, 03:38 PM
Licensed User
Shuie's Avatar
the port size thing is throwing me off
From BA's book, the port sizes
2.7RS 36mm
3.0RS 39mm
My throttle bodies are 39mm. Can someone confirm that this setup is NOT from a 3.0RS?
Old 12-18-2004, 05:18 PM
randywebb's Avatar
I think you need a different (and probably custom) space cam - not an MFI expert tho.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-18-2004, 05:37 PM
Elombard's Avatar
Oh thats right its running the pump from the cam that is tricky. Wasnt there a guy on the board who did this 3 or 4 years ago and sold the car?
Old 12-18-2004, 05:40 PM
wot wot is offline
wot's Avatar
Hi
from this picture it looks like it is from a twin plug engine, RSR?
Erik
82 SC 3,6 73 RS Look
Old 12-19-2004, 04:56 AM
Licensed User
Shuie's Avatar
The RSR had slide valves or high butterflys intakes. Its definitely not from a RSR. Everything Im reading and being told leads to a 2.7 RS.
I'd love for someone to confirm the port size for a 3.0RS is 39mm. I know Hans can figure out the spacecam issue if the pump will not work well as is on my 3.2, but Id really like to know that the stacks and throttle bodies were going to work so I can address my heads.
Old 12-19-2004, 05:15 AM
I would rather be driving
jpnovak's Avatar
Very cool Sherman! If you can find the early SC (78/79) they will have a 39mm intake port. HMM if yours don't fit, they will fit mine.
That 3.2SS will rock with MFI!
Old 12-19-2004, 05:41 AM
Licensed User
Shuie's Avatar
Thanks Jamie, thats what I was thinking.
Problem is that I just got my now basically 100% new set of small port heads back from EBS. Now they have to be tapped for MFI injectors and ported to 39mm on the intake side. It never ends
Old 12-19-2004, 05:51 AM
Green Skull 006
Jim Garfield's Avatar
Great find Sherman! It's got to be a good story, c'mon.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 12-19-2004, 07:09 AM
drag racing the short bus
dd74's Avatar
Well, from what I know, the GE40 cams are pretty radical, so depending upon what your compression is (what is your compression?), you should have a lot more top end if you bore the heads. Torque loss on a little '72 should be neglible.
Wayne sells naked heads fairly reasonable. If you sell the fresh small port SC heads, you'd probably have enough $$ to put a dent in the cost of new heads which are bored out properly. But does anyone on this board want fresh small-port SC heads? Maybe if they're into keeping things stock - or are into torque more than top end power. So, in short, you might be stuck with boring the heads out anyway.
Whatever you do, don't get rid of that MFI...
The Terror of Tiny Town
Old 12-19-2004, 07:47 AM
BURN-BROS's Avatar
Kudos Sherman, great find!
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-19-2004, 08:20 AM
