MAS MAS is offline
Turn signal
I had a front (passenger side) turn signal bulb burn out yesterday on my 77 911S.
After removing the old bulb, I found that neither the new (1157) bulb nor the old one would fit back into the socket properly. Both seemed loose... even though I fiddled with the stupid things for over 10 minutes.
For example, the new bulb lit up OK, but only when I held in in by hand.
OK, so is there some little trick I'm missing here? Should I take the whole fixture apart just to change a simple bulb?
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 12-24-2004, 10:02 AM
randywebb's Avatar
rotate bulb 180o -- & not the prongs on the side of the base are offset axially
and... check the tabs in the socket - make sure they are not bent too low
clean it all up carefully & smear a thin touch of dielectric grease on the mating metal portions
be sure th rubber vent thingie is in the housing and is open and clear.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-24-2004, 11:46 AM
RANDY,,,Isn't it ORGAN (m' just being a wise ass)
PCA and BMWCCA member for many years
09 Boxster Base PDK (No spare tire)
05 M/B CLK 500 AMG (Spare tire)
07 BMW 530xiT (Spare tire)
Old 12-24-2004, 11:48 AM
randywebb's Avatar
Or'gun
Old 12-24-2004, 12:09 PM
