tires run in wrong rotation
I just discovered that the installer mounted two of my new Bridgestone S-03 tires wrong. The directional arrows point backwards. I've put over 1,000 miles on them - far more than the amount of mileage to break them in.
Has any damage been done? Do I need new tires, or is it enough to just reverse the two tires on the rim? Thx.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
look out Im going out on a limb offering advice
if they are the two fronts or the two rears cant you just switch em? boy im gonna look like a retard if im wrong |
1 front; 1 rear
but my question is about damage....
Automotive Monomaniac
No damage. Directional treads are more for wet weather rather tire carcass issues. Flip if you want (they will work better in the rain). It shoud be a free install considering they were mounted "backwards" last time!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
What about the effect that camber has on the tread? I know 1000 miles is not a great deal but if there is a good amount of negative camber, the car may pull if the tire is flipped around on its rim. Tre reason I say this is because I had a tire mounted incorrectly too. The front left. It had been on for a while and like a dodo I had it flipped when I replaced the rears. Well, it gave new meaning to "lively" handling.
James Milton '82 911SC Coupe '07 GMC Yukon '92 Jeep Cherokee Sport (rain car) |
If your alignment is "normal" I see no harm in running (or mounting) a directional "backwards" on the vehicle. If you are running extremes in alignment, you may have excessive wear on the "new" tire that will be very apparent (enough to cause even dangerous handling) when flipped back to the "correct" position. Good point!
I say get them to buy you new tires.
Gruppe B #22 Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6 Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo |
I'll second that but good luck on that one.
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
They're designed to roll one way for better traction, and I doubt going backwards for 1k miles would've done any permanent damage. They should definintely redo it for free.
The only thing that I've had experience with backward tires was that they caused a lot of vibration when I went above 55mph.
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Fuchs w h o r e
Clarification:
I flip 4x16x6 all the time. The S-03 flipped backwards suprised me on how good it still is in the rain when 3/4 worn. I flip about every 5-6k mi. Rear tire wear should be even for transaxle care imo. I always use a tire depth ga to monitor. Measure at left-right-center.
Directionals is for rain efficency.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Administrator
I flip mine all the time. I have over 3 degrees negative camber. No bad things have happened.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
