Taxidodger
High torque starter recommendation
Any recommendations for a high torques starter (for higher compression 3.4 engine)
Considering Tilton 3HP, WOSP, SSP, PMB, IMI - or wherever your experience has led you. thanks |
Location: behind the redwood curtain, (humboldt county) california
Wosp
I've got their high torque starter on my 2.8, with 10.5 JE pistons, spins right up :-)
Only have about 200 miles on the raging - restomod. No porblems, but have no idea of the potential long term durability. Probably be just fine. c |
I have had the IMI for a few years on an 85 with stock drivetrain. I installed it. It has been working just fine!
Brise Co-axial starter. Tiny, doesn’t weigh much, used by Singer
https://brise.co.uk/product/porsche-911-7635091axgac/?v=7885444af42e |
It's a 914 ...
The Brise unit sure looks nice, the fact that it's used by Singer is a good endorsement. Under 6 lbs is impressively light. A bit expensive.
Taxidodger
Thanks everyone - appreciate the speedy replies
Burnin' Rubber
Wish I’d seen that offering before i installed my big ol’ heavy Bosch unit. I shoulda went hi-torque and small size. Oh well. Next time |
An IMI 101N is 25% the spend of that Brise. But if you have the dough for that show....
Call 911
I've equipped my '88 911 with the IMI starter several years ago. Being a reduction-drive starter, it cranks the engine a bit slower than the OEM Bosch. But the engine always starts after about a 2-second crank. I'm pleased in all respects.
Dave Kirk My Porsche restoreth my soul. |
Still here
Burnin' Rubber
And this is before you figure in whatever tariffs are arbitrarily applied to the shipment.
Ass-engine Nazi slot car -- PJ O'Rourke |
I went through two different Bosch starters, one new out of the box. When I did a long road trip of 10 to 12 hours in the summer heat, the Bosch starter would get a heat soak, and just lock up and be non functional. I had both checked at starter rebuild shops. Both said it is now fixed. They were wrong. They worked just fine is around town driving. It was the worst if I arrived at the hotel after a long drive, stood in line, and registered, got my room key, and a map to my room. 20 minuets time. Them I had to push start the 911. ![]() I have had my high torque started for 60,000 miles and many more long summer time trips, and it always spins the engine as designed. It is a wonderful sound that sure beats silence when twisting the key.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Call 911
Reduction drive starter sound reminds me of a '70's vintage Plymouth Belvedere with a 225 cu in slant 6. But you get used to it. Reliability is what counts.
Still here
Haha, of course it's true.
Cheers ! Quote:
And yes, my beloved air cooleds will never be as reliable as my Honda. Cheers to you both too !! |
