Registered Cruiser
Fuse or Relay? Or.....?
My fresh air blower motor stopped working. Even though I recently replaced it. At the same time my cig lighter and rear defrost also stopped working. Could this be a single fuse (I checked and all fuses "look" ok) a relay, or is it a wildcat strike for better working conditions..........
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
fuse #6 or the connection on either side of it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Registered Cruiser
Clarence,
Thanks very much for the info. Will try first thing in the am.
I have found that these ceramic type fuses can look just fine on visual examination...they might even check out OK with a meter...but, there can still be a continuity problem thru the fuse (on again, off again). As cheap as these fuses are, just replace the suspect fuse and you might find success. I've had this problem with turn signal and cruise control fuses on my '89.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
Registered Cruiser
Yep. Fuse LOOKED fine but the contact ends were black. Cleaned offending ends and Voila! now I can drive AND breathe heavily at the same time!
Thanks again for the posts.
I love an easy fix! Good work and thanks for letting us know the outcome.
Thanks to those who contributed to this thread. You saved me some grief as this car was on its way over on monday!!!!
![]() Now instead of chasing electrical gremlins, I have to look at the sunroof Just kidding Jorian, I am glad this was an easy fix.Please note I am making an attempt at humor!! Cheers, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
