Licensed User
Shuie's Avatar
Where is the type number on a 915
I can't find it. I found 3 casting numbers, but I dont see a 915/?? number. Where's it at?
TIA
Old 12-31-2004, 03:51 PM
The number is stamped on a large flat boss underneath the differential, near the drain plug.
Old 12-31-2004, 04:12 PM
Licensed User
Shuie's Avatar
Is that where the serial number is also?
Old 12-31-2004, 04:42 PM
The number should be 915/tt xxxxxxx or if you are lucky 915/tt 12 xxxxxxx. The tt would be the type, the xxxxxxx would be the serial and the 12 would be for factory LSD.
Old 12-31-2004, 04:55 PM
Licensed User
Shuie's Avatar
Negative on the LSD for sure, the shafts spin in opposite directions when you turn them by hand.
Thanks for the help!
Old 12-31-2004, 05:45 PM
