ishmeal's Avatar
does a porsche have to be expensive to own?
So I've heard it costs a bit to keep a porsche running, anyone want to share their secrets to keeping costs low? I know there are some out there that have been able to run their porsches w/o paying the premium. Share, share, share.
minivan - all stock
Old 12-28-2004, 05:56 AM
Licensed User
Shuie's Avatar
Expensive compared to what? A Toyota? Yes. A Ferrari? Probably not.
I've been through my car from one end to the other and I have yet to find anything that was cheap. DIY is the only way its affordable for me. They are easy to work on if that helps.
Old 12-28-2004, 06:05 AM
Irrationally exuberant
ChrisBennet's Avatar
I think the biggest factor in getting a lower maintenance car is buying one that has a history of good maintenance. These cars are very robust so even when maintenance is deferred they will keep going. When someone buys one of these "good deals" they often find that they wind up paying the big bills for the PO's neglect.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-28-2004, 06:22 AM
ishmeal's Avatar
If I get similar reliability from an early porsche as I do my bmw E30, then I'd be pretty content. It requires regular maintenance, attention and regular service too.
minivan - all stock
Old 12-28-2004, 07:48 AM
If you mostly DIY, I don't think they're that expensive to maintain, assuming you have a well maintained car to start with. As long as I don't need to drop the engine, then it's cheap to me. (I don't have the tools or experience yet to rebuild the engine, replace clutch etc.)
What I mean is if you're going to pay $95.00 per hour to change out easy stuff (distributor, plugs, etc) then it'll cost you. So get a well maintained car and DIY as much as you can.
-Steve
'87 Carrera Targa
Old 12-28-2004, 12:12 PM
Autobahn Garage
Buy the books ie (101 Projects for your 911 & How to rebuild and modify you 911 engine) These are like bibles to a 911 owner. Get them from Pelican you will be glad you did!!!!!!!!!
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 12-28-2004, 12:24 PM
epbrown's Avatar
Re: does a porsche have to be expensive to own?
Maintaining a good example isn't expensive at all - paying to repair problems or upgrade the car is what gets you. The best way to save money on a Porsche is to buy a good one up front, and don't get caught up in the upgrade spiral that lurking on Pelican and Rennlist can tempt you into.
Over the 4 years I've owned my SC, I've spent between $1000-$1500 a year. I've spent about $500 on my 944 in the year I've owned it, and nothing on the 928 so far.
Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers
Old 12-28-2004, 01:09 PM
banjomike's Avatar
Assuming you have the well maintained car as a starting point like everyone above said, an important aspect to keeping costs down is to spend as soon as you need to. If something needs fixing, don't put it off, do it now. DIY will definately help. The problem is even a well maintained car will eventually need a new clutch, or a tranny rebuild, or an engine rebuild (God forbid, knock on wood, etc.) These are not cheap things and are way out of my DIY range.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 12-28-2004, 01:13 PM
kevjandon's Avatar
My two cents.
Here is what is stupid easy to do on a 911 yourself. If you don't do these items, a Posrsche will cost a fortune as the oil change alone will run about $150. The following uses only common hand tools, two jack stands and a floor jack at most:
Oil Change. 1 filter, two drain plug gaskets and 11 qts of oil.
Air Filter
Fuel Filter
Spark Plugs and Wires
Distributor Cap and Rotor
Transmission fluid Change
Belt Replacement
A little more complicated but can still be easily done in your driveway. These may require some speciality tools but the cost of the tools will pay for themselves after the first use:
Brake Pad Replacement
Bleeding Brakes
Adjusting Valves
Replacing Shocks
Stuff you might want to take to a mechanic if your not mechanically inclined. I.e. if you had to buy tools and a floor jack to do the items in the easy section, you will need to see a mechanic on the items below:
Alternator Replacement
New Clutch
CIS Adjustment on 83 and older cars
Alignment
Current Rides:
1999 Carrera
Old 12-28-2004, 01:20 PM
nostatic's Avatar
its not the heat, its the humidity.
Keeping them running isn't that expensive if you get a good one.
Keeping yourself from making modifications that enhance the driving experience is *very* hard to do however...
Old 12-28-2004, 01:22 PM
Unregistered
sammyg2's Avatar
LOL the best way to keep the costs down on a 911 is to take it on the track and get the racing bug, right Todd?
Old 12-28-2004, 01:37 PM
anthony's Avatar
What they said!
Buy a good one
Get a PPI
Do as much DIY yourself
don't defer maintenance
buy used parts when it makes sense (swap meets, classifieds, ebay)
Budget $1000-1500/year to maintain the car but have enough in reserve for a large repair. In some years you may only need an oil change and costs will be low and in other years you may need to refresh the tranny. Planning for it, will lessen the blow.
When you look at the depreciation on a new car, properly maintaining an older fully depreciated Porsche will seem cheap.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 12-28-2004, 02:47 PM
Banned but not out, yet..
RSBob's Avatar
Keep it as a garage queen, wash and wax regularly.
Old 12-28-2004, 02:52 PM
snip....
......snip
LOL...I just had to buy a floor jack and jack stands to do the items in the easy section BUT I also just did the alternator replacement all by myself. I used this forum and Wayne's book. In my opinion it was easy and I did it in one evening. Considering the cost that my LM quoted me the DIY job it was worth it.
So I guess what I am saying is if you ever have to replace the alternator then you'll probably be able to do it relatively easy with the proper resources.
Shane
1984 Guards Red 911 Coupe
Allen, TX
Old 12-28-2004, 03:18 PM
nostatic's Avatar
no no no. First you smash it on a chunk of concrete...*then* you track it.
Oh well, its cheaper than crack. Oh, wait...maybe not. Oh well, at least its healthy. Unless you smack a wall. Hmm...well, at least I won't be on my death bed saying "I wish I'd gotten a 911 and tracked it".
Old 12-28-2004, 03:35 PM
218lb Lap Timer
jtcmuga's Avatar
Being a DIY-er, I think bookkeeping all mods and adjustments, and recognizing which parts have finite life - sensors, clutch, etc - is crucial.
Cheers
Jojo
Jojo
'84 3.2 Carrera Coupe
'00 Jeep Grand Cherokee LTD
"If everything seems under control, you're just not going fast enough" -Mario Andretti
Old 12-28-2004, 04:51 PM
PorscheGuy79's Avatar
did you hear Wayne say something?
Try to buy the best one you can, break it yourself, have no money and, by necessity, you will learn how to fix and maintian it cheaply.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 12-28-2004, 05:31 PM
I purchased my first '82 SC five years ago and once all the bugs were worked out (first year), it has been extremely trouble-free. Here's the run-down:
1. Purchased for 12.5k. PO had just paid for an entire $10k engine rebuild, 4 new Bilstein greens, a new distributor, new clutch, and other misc items. He had receipts for around $12k. Needed to get out of the car so I naturally obliged.
2. As with all sweet deals there is something lurking in the basement. After about 6 months, the tranny did some strange things (stuck in reverse) which required a rebuild. $2k later, I had a great car with basically a new engine and tranny.
I don't drive it much since its our "fun" car but it has probably seen 10 to 12 HPDE track days, a couple autocrosses and coastal trips. I have put about 25k miles on the car. In the last 4 years, I've only had to change oil, change the belt a couple of times, repack the front wheel bearings, and get the valves adjusted once. The hardest thing is not to modify the car so that it's unreliable.
That being said, I just replaced the rear wheel studs so that I could install 14mm spacers. This was a pain only because I had to disconnect the e-brake stuff.
I have been very pleased with the reliability of the car and you can't beat the performance and fun factor. It has 192,000 on the chassis, 15k on the rebuild, and around 5k on the tranny.
The best advice is find the best car that you can buy for the money. Don't stretch your budget. Keep around 10% to 20% reserve after your purchase for items the PO "forgets" to tell you about.
But above all, enjoy the car! They're built to drive.
Jim
Old 12-28-2004, 05:46 PM
Make Bruins Great Again
Por_sha911's Avatar
The best way to keep maintenance costs down are:
1) DIY
2) Never, ever, total your receipts. Just estimate "aw, maybe a hundred or so.."
Joe
Old 12-28-2004, 06:28 PM
