Jeff Alton's Avatar
Qusetion for 3.6 converters
For those that have converted to a 3.6, what exhasust did you use and why did you chose that route. I am trying to see all the different options that are out there. If possible, could you also post a pic?
Thanks for the help.
Jeff
www.turn3autosport.com
Old 01-05-2005, 09:36 AM
Administrator
Jack Olsen's Avatar
Cheap option: Carrera exhaust
Medium price option: Modified 993 headers
Expensive option: B&B Headers
Not-so-good (for me, at least) options: GHL, SSI's or headers without heat exchangers.
I went with the Carrera for a while, and then switched to the B&B when funds allowed.
Old 01-05-2005, 10:11 AM
Jeff Alton's Avatar
Thanks Jack
Old 01-05-2005, 10:12 AM
Have you done a search? This topic has been well documented innumerable times
Old 01-05-2005, 10:16 AM
I went with a B&B exhaust because a used one came up at a decent price when I was doing my conversion. Then, because I hadn't done my research, I had B&B make me a new, smaller muffler with cats, because I thought I needed them. Turns out I didn't, and they look real purty sittin' there on the shelf...
Old 01-05-2005, 10:19 AM
Jeff Alton's Avatar
I have done a search, thanks. Thom and Jack, are you running the 1 3/4 or the 1 5/8 headers?
Jeff
Old 01-05-2005, 10:42 AM
Me like track days
Craig 930 RS's Avatar
I went with B&B for my conversion. They had fitment problems with my set. Get 1 3/4".
1 7/8 from Timmins is IMO too large for a non-race motor.
Without a doubt, if I did it again I'd go for the Timmins' headers.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-05-2005, 12:14 PM
Jeff Alton's Avatar
Thanks Craig, I just talked to Timmins today and that looks like the best way to go.
Jeff
Old 01-05-2005, 01:59 PM
Me like track days
I'd like to think I've got a big case of BTDT and will dispense 3.6 transplant advice to anyone willing to learn and listen
Old 01-05-2005, 02:43 PM
Bill Verburg's Avatar
I used ssi at first, great for street, rotten for track, B&B 1 3/4" od are fair to good(if heat is needed that is the fair part). Steve is also selling some headers he and McNeil out tigether, that might be another option.
Whatever you do skip the B&B mufflers, they su*k, Flowmaster crossflow plumbed in w/ 2.5" ss pipes works well but is loud.
Mine B&B 1.75, Flomaster
Bill Verburg
Old 01-05-2005, 03:00 PM
Me like track days
Bill effectively has the same setup as I do - I have the steel (custom made locally) instead of stainless Fabspeed that Bill has. Go stainless and learn from my mistake!
Old 01-05-2005, 03:04 PM
So what is it that sucks about the B&B muffler? I've never known anything different.
Old 01-05-2005, 03:29 PM
I had 5 of them fall apart before they stopped honoring their lifteime waranty, and the passenger side outlet from the can is ~ .75" on the newer ones.
Bill Verburg
Old 01-05-2005, 03:35 PM
blue82coupe's Avatar
I used the stock 993 heat exchangers, with the Timmons /Mcneil muffler.The muffler was sbout $1300.00. Sounds great.Nicely crafted bit of work. Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 01-05-2005, 03:49 PM
Friends of Warren
911teo's Avatar
i went with the Timmins' package. Instant-g stainless steel exhaust plus cat plus headers... 1 3/4 as Craig was saying.... At 3k it is not cheap... Will let you know my impressions when conversion is over...
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 01-05-2005, 03:50 PM
Jeff Alton's Avatar
Thanks everyone. Craig if you are full of free advice I am sure we will be in contact!!!
Jeff
Old 01-05-2005, 04:27 PM
efhughes3's Avatar
Jeff:Is the 3.2 upgrade off of the table now, or are you weighing both options still?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-05-2005, 06:11 PM
CBRacerX's Avatar
Timmins "Happy Crab" Muffler with 993 Heater Boxes. See this thread
I got crabs this weekend!
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-05-2005, 07:44 PM
Me like track days
After numerous dyno tests I've done and seen from various 993 engines on the same dyno, I am convinced that headers add *zip* over the stock 993 HE's --
Old 01-05-2005, 07:59 PM
MuffinMan's Avatar
I went with stock 993 heat exchangers and a Triad 3.6 muffler due to cost and sound. The heat exchangers supposedly flow great, but I cannot attest one way or the other for the muffler, as I haven't dyno tested any other options. I love the way it sounds.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 01-05-2005, 08:54 PM
