strep's Avatar
These look horrible. Please Help.
Do I have these painted or anodized. Do they go to the body shop with my other parts. Or some where else. Does the body shop powder coat. I would like these perfect as the are a main part on the door. I would buy new but its way to much. Thanks.
Old 01-06-2005, 09:16 AM
Wurth Satin Black would probably do the trick....Pelican sells it.
You'll have to ask your body shop if they powdercoat.
Warren & Ron, may you rest in Peace.
Old 01-06-2005, 09:31 AM
If you are thinking between painted and anodized - I'd go with anozided. They came from the factory anodized, and they look crappy because someone painted them.
Old 01-06-2005, 09:37 AM
creaturecat's Avatar
nice used ones are readily available
nice doggie
Hetmann's Avatar
I had the same problem. Mine looked like they had been previously painted. I went with some nice used ones with original finish. I could never find anyone locally to anodize these or my lug nuts. No one wanted to mess with such a small order and I couldn't find a DIY way to do it either.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 01-06-2005, 10:26 AM
ipapilot's Avatar
Harbor Freight has their powder coat kit on sale for $60 plus another $10 for the material. Might be worth considering doing yourself!
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 01-06-2005, 10:58 AM
Learn something everyday...I could've sworn they were painted .
Old 01-06-2005, 11:02 AM
Send a message via AIM to Oldporsche
Cool
Aren't those painted over chrome?
You might ask your body shop guy what to do.
Paint doesn't stick to chrome. There is such a thing as black chrome that can be done by some plating shops. Anodizing is an electolytic process and not paint.
David Duffield
Yeah, you don't give the year of the car. If it is an earlier car with chrome handles, they are made of steel and I don't believe they can be anodized. You could have them blasted and powdercoated and they would be very durable, though.
From the pic, it looked to me like under the chipped paint is faded anodize. If that's the case, they could be reanodized, which would be the best way get them "like new" again, IMO.
Old 01-06-2005, 11:15 AM
There is a way to DIY anodize.
http://www.focuser.com/atm/anodize/anodize.html
http://www.caswellplating.com/kits/index.html
Old 01-06-2005, 11:44 AM
David Duffield
I've heard this over and over....Was I just lucky?
I painted my chrome bumpers on my suburban about 4 years ago and have had no problems at all, I scuff sanded w/ like 80 grit, cleaned w/ acetone, primed, and painted.
Also the car guys on Speed had a new product that is supposed to stick right to it.
Scott
Old 01-06-2005, 11:48 AM
What year is the car? the handles are either chromed, or black chromed. They are not anodised. Your best bet is the same paint as the Wurth satin that is so liked for Fuchs rims.
Old 01-06-2005, 12:26 PM
I painted mine with Wurth a week or so ago. I stripped with a 150 or so sand paper. Then used that self etching primer and then painted shortly after, within the time frame suggested on the primer can. Does this mean my paint is going to fall off. When I put them away, they look great.
Should I clear coat? I was planning to.
Old 01-06-2005, 12:33 PM
strep's Avatar
87 911 Carrera. Thanks Guys.
Old 01-06-2005, 02:37 PM
l modded mine with carbon fiber 993 molded overlays...
my life begins at 150MPH
Old 01-06-2005, 06:12 PM
geof33's Avatar
I've got a pair that look like new I'll sell to you for 50.00. Let me know.
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 01-06-2005, 06:26 PM
Yellowbird RS's Avatar
get a 993 ones
X/A
Old 01-06-2005, 06:36 PM
Geof33, I'll buy at least the driver's side if Strep doesn't need both of them. Sent you a PM just now.
Aren't the handles the same on either side, just flipped over?
CConnor
73E targa
89 Coupe
Old 01-06-2005, 06:45 PM
frankc's Avatar
The black 911 door handles are not anodized - they are black oxide. I took mine to a plating shop years ago to be refinished, and the guy there said he never saw such a procedure used for car parts as it is expensive. It is a multi-step plating process that he had to strip off. The base metal is plated with another metal - copper or something. The the black oxide is applied to that metal.
Mine still look like new after about 15 years since the refinishing.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 01-06-2005, 06:53 PM
