POVI's Avatar
RSR backdate update and help on backdate of pop outs
Hi
Wanted to share my current status of my 2.8 RSR body backdate
on a 1979 non sunroof SC ..
Have body stripped , and test mounted set of nice early 911 doors
with early chrome trim on body.
I need a pic or the pillar where the quarter windows mount , as im installing a set of early pop out quarter windows in place of fixed quarters.
Any hints on installing early pop outs on a sc body ?
It looks like there is a small vertical panel spot welded over the original slots where the pop outs would insert , as there is bolt holes and threads already there .. If you have experience installing pop-outs please post ..
Thanks in advance - Joe -
Here is picture ..
Old 01-08-2005, 12:39 PM
nice doggie
Hetmann's Avatar
I put pop-outs on my 78. I found a black set at a local dismantler. The captive nuts were present in my b-pillars and there were holes for the latches in my c-pillars. I had to put "nut certs" into the holes in the c-pillars. This is easiest to do with the rear glass out. I had to remove some sheet metal "trim" from the outside of the b-pillars. This will be obvious to you when you get things apart. I pieced together how to do it from several searches done here. Each gave a detail of two. The windows bolted right in and fit nice and snug. I am very pleased with this upgrade.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 01-08-2005, 09:08 PM
