Question 73' 915 Tranny with 3.6L Engine?
Hey guys I need to know if the 915 tranny from a 1973 911 will fit on 911 (964) 3.6 liter from a 1992 C2 America Roadster.
Old 01-11-2005, 08:06 PM
Send a message via Yahoo to Lukesportsman
Not directly, but it can and has been done. It requires adapters if as I'm guessing your putting the 3.6 in an earlier chassis and not the trans in a later.
Do a search which can be tricky since "3.6" can't be part of the search...needs 3 letters. There are MANY threads on here about such. Dr. Steve Timmons and Patrick Motorsports are two places you can gain a little knowledge.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-11-2005, 08:48 PM
Bill Verburg's Avatar
Yes, you will need a custom flywheel from either Patrick or Timmins and some shorter bolts
Stock 915 c/pp wrks fine but I would use a new one.
Beefed sideplates and a cooler for track use are advised.
Bill Verburg
Old 01-12-2005, 01:59 PM
Administrator
Jack Olsen's Avatar
You also need to notch the bell housing for the 964's speed and reference sensors. But yes, it can be done. It probably doesn't make sense if you're replacing the Roadster's tranny. But it's the best way to go if you're swapping a 964 motor into a 1973 tub.
Old 01-12-2005, 03:44 PM
