spring rate question. (coilovers)
What spring rate should I be shooting for on my 84 carrera. I got a deal on some coilovers that I could not refuse and am not sure what spring rates to go with. Car is used daily and sees about 10-12 track events a year aswell as 6 autocross. Weighs 2450lbs, Elephant swaybars, strut brace. monoballs, and polybronze bearings. Soon to be transplanted warmed over 3.6.
Thanks for your help. Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff:
Long time with no response.....don't know if I could help but the torsion bars used as factory around these years was something like 19mm front and 24.1 or 25 mm rear. Equates to about 120 lb/in spring rates, as I recall from my posted charts...more correctly "wheel rates". The coils you want to use....even assuming you want to duplicate these settings ( doubtful, I would guess)..would depend where on the suspension these mount. The altered leverage factor you get at various mounting points on the suspension arm, would end up with a different "wheel rate"..which is truly what you're after....not pure spring rate. I'm not sure if I explained this clearly enough..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil, thanks, I do understand what you mean. I am looking for feedback on what people are using in their cars for rates. I phone one well known shop and they say 600/400. Then I phone SRP and they say 300/200. Getting a liitle confused. The car has 21/27 in it now but I was looking to replicate something like a 22/30 or 22/31 set up. I PM,ed Jack Olsen and he is running 600/400.
Thanks, Jeff
Administrator
19/25mm torsion bars are the equivalent of coil springs with 110/140 pound spring rates. 23/31 torsion bars are like 250/332 pound springs. (At least, I think these numbers are right. I'm trying to find where I wrote them down.)
(My 400/600 springs are the equivalent of, well, really huge torsion bars.) I would still suggest you sell the coil kit and keep your torsion bars. The pieces themselves are just a small part of what it's going to take to switch over to coils. You need to modify the chassis, especially in the rear. And unless you need more than a 23/31 torsion setup, there's not going to be any payoff for all the work.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Administrator
Thanks to Wil Ferch, for this data:
Front Torsion Bars 18.8 mm = 110 lb/in 21 = 173 22 = 210 23 = 250 24 = 296 25 = 350 Rear Torsion Bars 23 mm = 100 lb/in 24 = 120 25 = 140 26 = 165 27 = 191 28 = 221 29 = 254 30 = 294 31 = 332 32 = 377 33 = 427 All the information is at this link.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 Last edited by Jack Olsen; 01-09-2005 at 10:40 PM.. |
The work is the fun part!! I am going to reinforce the rear shock mounts. and run with the rear 935 style spring plates and possibly the 935 style front a arms. I like the idea on being able to easily change the spring rates as well. I realize there is little benefit to going the coil over route, but I like being just a little different!! I want something a little bit different from the next guy I guess. This car may also end up as more of a track car and less of a street car in the future. I just like doing things that not everbody does. I know that may make me seem like a bit of a .... ummmmm.... dare I say fool, but it's my hobby.
Jeff
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
