Originally posted by Erakad
I like the economics of the $120 condensor, but not the fabricaiton.
Fabrication / Install is very painless. Never can have too much condenser.
Heat Shield / Guard not installed. Though you can't tell I polished the aluminum mounting brackets, I was going to send them to my cousin, Al Reed, but I was crunched for time.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 01-10-2005, 07:15 PM
Scott,
I found a place that has a 12 x 15 serpentine condenser for $50.00 This may be a better choice for the front of the wheel location.
Also, where and how are you getting R-12? Do you have a 609 Cert? I've also heard that R134 is going up in price.
Bill
Old 01-10-2005, 07:18 PM
never ending projects
niner11's Avatar
I think I picked up the condensor on ebay for about 140.00 or so. The procooler was a bit painful to stomach but I have a black car in Atlanta and I've had about enough or sweating in traffic. I'll post pics of the install when it happens but it will probably need to get a little warmer outside to motivate me.
Does anyone have the DIY guide for making you own vac pump. I think somebody had instructions showing how one can be made out of an old refrigerator compressor
Thanks, Chuck
Old 01-10-2005, 07:30 PM
Originally posted by niner11
Just picked up a procooler and a 964 condensor to be mounted on the left front fender.
What are the dimensions of the condenser?
Bill
Old 01-10-2005, 07:34 PM
The only problem with the fridge compressor is that it really heats up. You can get a vacuum pump on EBay for about $70.00
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4844&item=5354176108&rd=1
Bill
Old 01-10-2005, 07:36 PM
niner11's Avatar
roughly 14''x 11"x 2" on the condensor. So your telling me I need to put on condensor on my homemade vac pump too
Old 01-10-2005, 07:46 PM
Sorry, wrong link.....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7945632785&category=46094
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=53287&item=3865112306&rd=1
Bill
Old 01-10-2005, 07:47 PM
How about this, everyone send me $3.00 and I'll pool the money together and buy a good pump and we can all share it. Of course, we'll keep it at my house when it is not in use.
Bill
Old 01-10-2005, 07:49 PM
scottb's Avatar
Originally posted by TRE Cup
Scott- didn't you have an aftermarket condenser unit in the left front on your car? i though that was working out well
Dave: I do, and it does. But there's always room for improvement. At the very least, there's always room for another winter project!!
1984 Targa
Old 01-10-2005, 08:00 PM
scottb's Avatar
with a 964 cooler- it mounts pretty low on the 911SC/ Carrera- even if you angle it in. the back of the headlamp bucket could need some mods too
My aftermarket condenser fit fine, without any mods to the headlight bucket. Here's a picture. As you can see, it fits in place of the washer bottle and vapor recovery tank. (And yes, I did mangle some of the fins. I straightened many of them before I buttoned everything up.)
1984 Targa
Old 01-10-2005, 08:04 PM
okay - yeah that looks decent. what was the name of the co. in san diego that sells this? also, is it robust enough so rocks don't create leaks? if not you may want to think about some sturdy stainless screen to fab a rock shield.
with the exception of all the extra hoses and fittings ( a necessary evil) an additional unit mounted in front of the left rear tire would help. think about using a marine 3" duct fan if there is not enough room for the flat fans seen on this post. you can direct the air with some shielding over the rad.
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 01-11-2005, 11:37 AM
scottb's Avatar
Dave: I bought some "sprung steel" from Home Depot to serve as a rock guard. I cut it to fit, bent it to protect the bottom of the condenser, and then painted it black. I also took some 3/8" tubing and split it so I could put it all around the edges of the rock guard (that sprung steel is like razor wire after it's cut). It all worked out pretty well, if I do say so myself. Next time it's in for service, take a look!
The company that sold me the parts is www.iceac.com. Fan, condenser and hoses ran about $300.
1984 Targa
Old 01-11-2005, 12:32 PM
Erakad's Avatar
So Scott...did you keep any of the other condensors, or is that the only one? Any directions come with it, and finally, have you...or any of the rest, thought about writing an article...what a huge benefit to the entire community.
thanks
Rob
Black 1983
911 SC Coupe
Old 01-11-2005, 04:41 PM
scottb's Avatar
Rob:
Other condensers? -- Yes, I kept all of the factory condensers, and added the fender condenser/fan.
Directions? -- No. I made it up as I went along.
Article? -- I hadn't considered it. It's not a difficult installation. It connects "in series" with the other condensers. Basically, the a/c hose that goes through the wheel well to the factory front condenser is rerouted to the new condenser. Then, the output of the new condenser is connected to the input of the original front condenser. The fan is run through a basic relay, with the trigger being the power line to the existing front condenser fan. Frankly, I don't remember where I got the power for the fan, but I did put an in-line automotive (blade) fuse in the circuit.
Scott
1984 Targa
Old 01-11-2005, 04:54 PM
CBRacerX's Avatar
www.iceac.com doesn't seem to have a web site working at the moment...
Edit: 1/12/05 - Up now
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-11-2005, 08:44 PM
scottb's Avatar
I just tested it. Works fine now.
1984 Targa
Old 01-11-2005, 09:02 PM
niner11's Avatar
Has anyone found an evaporator that is more efficient than the factory one. Found a website that sells an entire kit for reasonable money but I just want to buy their vent and evap
www.retroair.com
When using 134 is it necessary to change to a different expansion valve also? I'm pretty sure that the weakness in these earlier 911's is primarily condensor area. Second to that would be air flow so I'm wondering if it will even make much difference to change the factory evaporator. Any ideas? Thanks, Chuck
Old 02-08-2005, 03:37 PM
scottb's Avatar
$1400 for that entire kit is a fair price....
1984 Targa
Old 02-08-2005, 03:44 PM
Guys,
the trick is get as much air through the condesor as posssible.
need r-12 email me, doing a new system replace the receiver/dryer $85.00 ok email me.
keith epperly
87 slantnsoe turbo look carrera cabriolt
Old 02-11-2005, 08:51 PM
rfuerst911sc's Avatar
niner11 I was told by a respected local Porsche wrench that when converting to R134A that the expansion valve had to be tweeked / adjusted for optimal performance.I decided to go with HC12 so I never took him up on his offer to adjust my new expansion valve.
Old 02-12-2005, 01:51 PM
